Easy Hollower
Mark
Has any one used one of these tools? I am looking to buy a hollower that's easy to use and is under $150. Thanks for your help.
Mark
Easy Hollower
Mark
Mark
What do you define as "hollowing?"
steven antonucci
Re: What do you define as "hollowing?"
Mark
I guess I should have been a bit more specific. I plan on doing small hollow forms, nothing more than 6" by 6" by 6". Making smaller hollow Christmas ornaments and the like. Does this answer the question?
Re: What do you define as "hollowing?" *LINK*
Carole Valentine
Personally, I think you would be much better off spending about $20 more and getting two sets of the Kelton hollowers - 1/2" or maybe even 5/8" for the hollow forms and then a set of the 5/16" for Christmas ornaments. There are three tools to a set - straight, gentle curve and acute curve. Very versatile tools. They are my go-to hollowing tools. You can take a look at them at Lee Valley.
Lee Valley - Kelton Hollowers
Ken Vaughan
for small hollow forms and ornaments -- and I am thinking of about 3 inch circles as teh starting size on ornaments, this tool is too large to give you easy handling. For the hollow forms, you will probably still want a second tool for the bottoms.
Yup -- I have one and it works fine on hollowforms especailly those at least 6 inch in diameter or larger.
You might want to think about some small tooling for ornaments. Bob Rosand sells a small silver soldered angled HSS bit on shank and handle for abou $20 and then there is the small hunter set that is sized about right for your objectives.
Re: Easy Hollower
Since i don't have an easy hollower I can't comment on how hard or easy it is to use. I would think it's too large for Christmas ornaments. I hollow mine through a 1/2" hole and the balls are never larger than about 2".
All of the hollowing tools I've used have a learning curve. If you take too big of a bite you get a catch. For most hollowing you really only need 2. A straight tool and a bent tool.
The bent tools that only have one bend are more prone to catches because of the forces trying to twist the tool. The tools that have a Question mark sort of bend are designed so the cutter is aligned with the straight part of the shaft. If you keep the tool rest on the straight part then they don't have the twisting motion. You can still get a catch but it's the same as a straight tool.
It's easy to make your own in those sizes. I use Drill rod for my ornament tools and make them with 5/16" rod. Just grind the end to shape. If you want them to hold an edge longer you can heat treat them which can be done with a propane torch. 1/2" rod will do a 6" vessel.
Here are some close ups of my Christmas ornament sized tools made from drill rod.
If you want to get a little more exotic and have some metal working skills you can add Carbide or HSS cutters to the shafts.
If your going to purchase a set I think the John Jordan 1/2" set would do a great job. They are a little too large for ornaments unless you make large ornaments.
Homemade John Jordan style tools
Sorry meant to post these along with the above post. Fingers work faster than brain especially in the morning.
I originally made these tools with set screw(that's why the holes are there) The set screws get in the way and are not needed. CA medium glue works just fine. Just heat them if the tip ever needs to be removed.
On larger tools that are heavy and it makes it difficult to grind the tips I do use the set screws. Then it's very easy to pull the tip out and grind it. On 1/2" tools it's not necessary.
Exactly what John does
steven antonucci
If you are going to stay small, go to your local home store and buy a piece of cold rolled steel to drill the hole. Like John, I glue 5/16"- 3/8" and under, and set screw anything larger.
If you get below 5/16", it is just easier to use a tool steel directly. O1 is cheap, and can be bent easily at this diameter. It will take an edge directly and you should be able to get an entire set out of 1 3' length. Probably costs you $2.
Steve
Re: Easy Hollower *LINK*
Alan Zenreich
I have 5 of the Easy Wood tools 3 full size and 3 mini
For small hollowforms I think even the minis are a bit large shafted.
I recently acquired some of the new Nano Tools from Jim at Warren Cutlery.
I bought the standard set, then added a few handles, a round carbide cutter and a scraper. Very nice tools for small work
Shown below is my very first hollow form... mahogany, wall thickness a bit less than 1/10"
