Vacuum pump
Vacuum pump
Vacuum pump
Ted Evans
Does any one have a suggestion as to where a Gast 0522 or 0523 pump can be obtained? I have checked Surplus Center and Ebay without success. Surplus does not have any and what is on Ebay seems expensive to me. I have a Hold Fast system that works very well and was quick and easy, however, I would prefer not running a 5hp industrial air compressor for a vacuum chuck.
Thanks for any suggestions.
Ted
Re: Vacuum pump
Re: Vacuum pump
Carol Reed, Strawberry, AZ
Check around where you are for industrial liquidators. I found a whole pile of them in a place in Phoenix a while back.
Re: Vacuum pump
Re: Vacuum pump
Grant Wilkinson
I just searched on Gast on Ebay and saw one 522 and two 523's on the first page.
Re: Vacuum pump
Re: Vacuum pump
Ted Evans
Thanks Carol and Grant. Yep, I got one from Ebay but it was not in the "less than $100" range that I have seen so many others get. I just got tired of looking, now I must start acquiring the other components needed. Thanks again.
Ted
