Rusty old platters
Rusty old platters
Rusty old platters
Terry Scott
2 Rimu Platters Part of last months effort
Almost all of the bowls face down have epoxy inlay-ed rims .
The rest
I have just sprayed all the bottoms .To keep my sanity when doing a run like this I do a few decorative pieces in between
These bowls were wet turned last October so well dry all Ancient kauri
I have taken a bit of a punt as I have just started suppling a large shop at the airport who in November are opening an even larger store and the way the last two months have gone I dont want to be caught with my paints down
I had a mate around to show me how to do the epoxy.The first thing was to make up a quick hot box ,and play around so we had 22 degrees c
If the shop doesnt take all these no matter Xmas is just around the corner
http://en.wikipedia.org/wiki/Dacrydium_cupressinum
Both platters are 500mm Dia
I am having fun with my new friend Rust and verdigris effects
I think the contrast works well
Cheers
Re: Rusty old platters
Nice platters. When doing epoxy did you learn anything about air bubbles. I've had problems with air bubbles in any medium that resembles epoxy. I've used several types of epoxy, Inlace and Polyfil. I've had air bubbles in all of them. It seems to vary with the time of year, probably a temperature thing. It's always been a battle.
Bill Neddow
An incredible amount of beautiful work, Terry. I don't know how you are so productive!
Leo Cuellar
I give up..."Sweet"
Leo Cuellar
Wow Terry! Not only quality but quantity as well. The rust effects just keep getting better. Very nice run.
charlie belden
I keep wondering when you find time to sleep.
Now I'm starting to wonder if there will be any wood, or trees, left in New Zealand, given your turning prolificy (is there such a word?). Given your creative productivity - acrossed a wide range of forms and textures and surface treatments - surely you've denuded half the forests in your area ; )
This current Rust Run seems to have your innovative and creative juices gushing - each piece really nicely done and interesting. But the QUANTITY - amazing.
Re: Rusty old platters and epoxy
Terry Scott
Hi John
The Resin I used is by info@gemco.net.nz
http://www.gemco.net.nz/ The same stuff Alby Hall uses Tim will post over seas
Its not overly expensive at $65 for a ltre
Specially designed for casting doesnt yellow and is clear as cristal
Step one
Dig your trench and then apply 2 coats of sanding sealer taking special attention on the end grain so you dont get bleeding
Step 2
With acrylic Paint apply two coats over the sealer
Step 3
Set out you inlay
If using shells or seed pods that are hollow you need to either pre-full will resin or make up a vacuum chamber as any residue of air will one make them float to the surface and also the bubbles will come out as the resin heats up on curing
Step 3
You need to measure out your ratio of resin and harder by weight not my measure as the consistences/ viscosity of the materials are differnt
Step 3
Stir with a round dowel as a square stick makes more bubbles
Stir for at least 5 Minutes
Step 4
You need to preheat the epoxy to around 20 degrees c I have a box with a light bulb
Step 5
By a bag of sand and some plastic plates
this enables you to level the bowls when you pour
Step 6
As I did have a dust free area that is at a temperature of 20 to 25 degrees c
Step 7
pour in the resin
Then with a heat gun or a small butane torch wave it over the resin
The co2 removes the bubbles
You may have to do this 3 or 4 times over the next 2 or three hours
Step 7
The longer you can leave the resin to set the better, these bowls I left 4 days to make sure .If you cannot leave a depression with your finger nail its ready
Dam big learning curve but with Mikes help I only got one bowl that is a reject that was from not sealing the wood properly and the blue paint bled
Finishing the epoxy is another story
I am only to happy for you to email and we can chew the fat about the process
Cheers
I think you're pulling a Kiwi trick on us
Mike Foster
It is hard to believe that you have any time for a real job with the amount of work that you produce. In fact, I wonder when you take time to eat.
Keep it up Terry. Great work as usual.
Mike
Kiwi trick
bill Crommett
Is there any substance to the rumor that Terry has two doppelgangers that he keeps chained to the lathes, and that he is just the designer and the mouthpiece ?
