Torn grain problem
Torn grain problem
Torn grain problem
Starry S Chan
I rough turned a silver maple bowl cut from a half log today. I had torn grain at the end grain areas but the side grain areas are quite smooth.
The log was cut in March 2010 and the bowl blank was cut in July 2010. The bowl blank is not dry but it is not very green either.
Is this normal? If not, what may be the causes and how do I deal with this problem?
TIA for your tips and comments.
Starry
Re: Torn grain problem
That is normal for a lot of woods. In 2 areas of most bowls you are turning against the grain rather than with it. Sometimes you can cut in the opposite direction and it will get rid of the tearout here but introduce it on the 2 opposite sides. The overall tearout might be less so I leave it and start sanding.
Try these tricks. First of course, use a freshly sharpened gouge. You might even try going to a finer diamond hone to really clean up the edge.
Try not to force the cut. Speed up the lathe, slow down the forward pressure on the cut and/or both. This alone solves the problem many times.
Use a tool with a sharper cutting angle. My detail gouge is 35 degrees and one bowl gouge is 40 degrees. Using one of these with really light forward pressure often does the trick. If these fail I try the Hunter tool. It has an even steeper angle and will cut clean where other tools won't. You have to use it in a bevel rubbing manner, don't scrape with it.
Use wax. Often a coat of wax will make the tool cut cleaner. I've also used thinner lacquer and sometimes just spraying it with water will work.
Stop the lathe and use a rounded cabinet scraper on that area. You bowl won't be round anymore because you are lowering the surface but if you blend the edges in properly no one but you will know. It looks and feels better than the unevenness you get from using 80 grit paper.
Hope one of these works for you.
robo hippy
Silver Maple is one of those woods, at least for me that tends to have more tear out than other woods. Getting it wet, I use a wet rag, or spray bottle, and then taking a couple of passes with a freshly sharpened gouge helps tame it. Of course, the 80 grit gouge can finish it up.
robo hippy
Fred Holder
This problem is common with a number of woods, especially if they have become spalted. Often times, the sharpest gouge will not cut clean without tearout on the endgrain portion of the bowl. Several years ago, someone on this newsgroup introduced me to Cedar Shield, which later became known as Turner's Choice. If you are allergic to cedar, don't use it.
Here is ordering information: To learn more about this dynamic product visit www.cedarcide.com. To order call 1-800-842-1464.
I've used up several gallons of the stuff since I was introduced to it. You soak the wood in it for about 24 hours and let it dry for at least three days before starting to turn it. It makes the wood turn much easier, cuts cleaner and reduces tearout on spalted woods. If probably would do so on your wood.
One of my earliest experiences with this product shortly after I got the first order, was with spinner tops. I was making up blanks for a demonstration at the local carving show. I threw three of the blanks into the Cedar Shield. When I started to demonstrate at the show, I tried one of the Cedar Shield top blanks first. I was astounded, I was getting nice shavings off of endgrain cutting. I had to get a couple of other woodturners to witness it. The three treated top blanks gave fine shavings off of the end grain wood. The other top blanks did not do this.
Incidentally, I have no connection to this company or its product except being a user.
RussFairfield
A solution that has helped a lot for my turning the inside of Spalted Maple and other species that tear easily is to use a bowl gouge with a convex bevel fir the inside of bowls. This bevel allows the tool immediately behind the cutting edge to be on the wood and offer total support to the wood as it is being cut.
Our normal turning tools with flat or concave bevels are a good match for the outside curves, but don't always support the wood on the inside of a bowl because the pressure on the wood is back from where the cut is being made by the width of the bevel, and not immediately under and behind it where it needs to be to prevent tear-out of the grain.
You can help this problem by grinding a secondary bevel that is narrower, but the best solution will always be a convex curved bevel that places the tool pressure immediately behind the cutting edge on wood that wants to tear easilly.
There is a photo of this tool on WoodCentral at the end of the permanent article titled "Tool Grinds" that is listed under the "Odds 'n' Ends" in the index at the left of this page. It may help you with the tearout problems.
Keith Tompkins
Keith Tompkins
First, ensure your gouge is sharp...honing the edge before the final cuts can make a big differene. Like John said, go slowly...let the tool feed itself, don't try to push the cut. I roll the tool so the cutting edge appproaches the cut at approx. a 45 degree angle to shear away wood. Some woods cut cleaner starting at the rim and cutting towards the foot.
A link to the pictures
RussFairfield
http://www.woodcentral.com/newforum/grinds.shtml
