Veritas - Innovation in Tools
How fast can you turn a peppermill?
Paul Zerjay
I was at a show last weekend with another turner who said he can turn a mill from rough blank to finished mill in 1/2 hour. I didn't ask, but his finish looked pretty good...like several coats. He says he does all his drilling on the lathe. I made the first one I have turned in years today. Took me 2 hrs.
Re: How fast can you turn a peppermill?
Steve Kubien
Steve Kubien
It depends on lots of things...How good you are with a skew or how good a finish you can get with your gouge, what kind of mechanism are you using (Crushgrind or Chef Spec type)? How does the top interface with the body? Flat bottom or a fitted tenon? What kind of wood? Paul, you know all of this stuff, of course.
I think the two biggest factors are the type of mechanism and how you fit the top. Turning the tenon and fitting it nicely takes time and the Crushgrind mech requires 4 or 5 bits. I use forstner bits and of course I have to back them out frequently so they don't get stuck. With the retaining rod I secure my drill chuck with, I've only got a little over 2�" of ram on my tailstock so I have to reposition the tailstock several times. I hate drilling, a lot.
Oh, and as for � hour... I find that REALLY hard to believe if this guy is working from a rough block, say, 3�" square by 12" long. Ready to finish in 30 minutes? Maybe if his name was Richard Raffan. 2 hours is a little long for me but I make a fair number of them. I rough the blank, seperate the top, remount the body and drill it out (I use Crushgrind mechanisms). There goes over � hour.
Did I ever tell you about the 12lbs smallmouth bass I caught? Oh yeah, 2lbs test line too.....
Bill Grumbine (Kutztown PA)
Turn it as in making one, or turn it as in grinding the pepper? :b I find half an hour a little fantastic too, but then if he makes enough of them, some operations can be turned out faster than most regular people who do it occasionally can even form the thought process needed. Roughing to round with a skew, for example, can be accomplished in a matter of seconds. Jigs for forming tenons and such can also reduce time. When I was turning beer taps for the brewery, I could make a wooden beer bottle every five minutes.
When I was making nothing but pens, I could work at a comfortable pace and turn one set of tubes every four minutes, including sanding and putting the finish on. The fastest I ever timed myself was on a long run of the same pen and the same wood. I averaged one cycle every 2:40. I will probably never see that kind of speed again, nor do I care to contemplate the repetition that made it possible.
Recently I completed a cradle. The spindles in the sides were fairly complex and exacting. The first spindles took a bit of time - say an hour. After the first several, I was turning them start to finish in 30 minutes.
The blanks were rectangular blanks that had already been cut to length and had the centers "found".
So - do I find it fantastic - no. Not really. I've taken a class with Nick Cook and seen him demonstrate at some events. I've seen him turn some reasonably complex things in 1/2 hour.
I'm pretty sure Nick Cook could do it. I've watched his Pepper mill demo and he easily does the demo in an hour and that of course includes a lot of talking and discussions about the techniques he's using. He turns his wine stoppers in 3 minutes. Maybe less. He was talking to me when when he did the one I timed.
Me. I could turn one in about a day. I think I've only made 2 if memory serves me correct. They just never intrigued me. I do agree with JL. If you turn enough of anything you can get really fast. I turn my mirror handles in 15 minutes or less. They used to take about 45.
There is a new tool on the market that lets you drill all the holes accurately with this one boring tool. I saw it advertised in Woodturning. It looked like a good metal working project so a friend who makes pepper mills is going to come over some time and we are going to set up the dimensions and i'm going to try and build one. As near as I can tell you drill one pilot hole and then insert this thing and bore to the mark. All the other holes for the mechanisms are bored to size and depth in one quick pass. That would certainly speed it up. Couple that with the Vega duplicator and I'll bet you could easily get the time down if you did them in batches.
About 1200 rpm ;-))
Don Orr
