Lathe
Don at Central Illinois
I have an opportunity to purchase a used lathe that came from a high school. But it is three phase. I know I can get an inverter, etc. but is it worht it or not? How high are the inverters/converters?
Lathe
Re: Lathe
Bill Howatt
Here is a link to a commonly referenced source for inverters:
http://www.dealerselectric.com/mfg-subcat-item.asp?cID=28&scID=165&mID=-1
You have to get the unit that matches the HP of your motor and as you can see there is a variation in prices.
By going this route you can also get electronic variable speed with the appropriate inverter which is great.
It appears a 2HP unit can be purchased for about $200, give or take a bit. So add that onto the lathe and decide if it's worth it. Programming the units apparently can be a bit tricky and if you aren't familiar with electrical/electronic equipment and terminology you likely will need some help. There are people on this forum who have some experience with this.
BTW, what is the make and model of the lathe?
Bill
Re: Lathe
A Powermatic 45, for about $450 and it's only about a three hour drive from home.
Re: Lathe
Ron Lynch
I put a three phase motor and a VFD that I found on Craigslist into my ex-high school PM45 and it's great. I recommend the combination, beats changing pulleys.
Re: Lathe
What kind of money am I looking at for a VFD? If I have to pay close to retail for an older lathe plus the VFD, why not buy a new one? Just trying to get the most bang for my buck (actually SWMBO's buck).
Re: Lathe
Ron Lynch
I picked up my Craigslist VFD and Motor for $125. VFDs can be had for $100 on up depending on horsepower rating ($100 will get 1/2 HP drive, $150 for 1 HP). My local ABB distributor was selling off their stock of older ABB VFDs and I picked up a 1.5 HP unit for $75. I am planning to upgrade to a larger motor and couldn't pass up the deal. Three phase motors will run $150 and up new, generally lots cheaper used (think Clist and the bay). So figure $250 for motor and drive and another $25-$50 for switches, speed pot, enclosure, misc. Whether you want to sink that into an older lathe or put it towards a shiny new one is your call, but electrically variable speed is the best.
