here's my ebony project...
Garyg in Md
The MCW Ebony Challenge Show & Tell will be held Thursday evening.
Here's my entry.
The HF is a "practice piece" with Paul Fennell. Paul was very gracious in offering me an afternoon of instruction on my own lathe in the back yard while he was here for the festivities surrounding the opening of the Bresler Collection exhibit at the Renwick. Paul turned the lovely outside shape, and I did a lot of the hollowing. I got a real lesson in how deep to drill the pilot hole! Yikes! Let's just say it's not bottom heavy. (Thanks again, Paul!) Two coats of Bush Oil, not yet buffed. Nice chatoyance around the girth that doesn't show up in the photo.
The ebony finial is my copy of a favorite, elegant design by Keith Burns. I messed it up a little bit, but, overall, I think I matched it to the HF pretty well, and it'll do for my first-ever finial and first-ever use of real ebony.
(Sorry for the crappy photography, Jamie -- I still have a lot of work to do there.)
I'm looking forward to seeing what other members have done with their ebony scraps.
...Gary
Re: here's my ebony project...
dimensions... 3.5" dia x 7.13" tall
Garyg in Md
Cyril Griesbach
That's a beauty, Gary.
Re:Very nicely done Gary, and......
JamieDonaldson
...what finish did you finally select for the finial?
Garyg in Md
Jamie, No finish, per se. I sanded to 800, Abraloned to 4k and put on two coats of Ren. wax. It's actually a bit shinier now than in the photo because that was after the first coat, and I wanted a bit more sheen. If I wanted it shinier yet, I would Micromesh -- it appears to me that ebony is good on its own with no added material needed (or necessarily desired) unless you want it really shiny (which is not my style). ...Gary
(Message Deleted by Poster)
charlie belden
excellent comment...
Garyg in Md
You got me there, Charlie. I like your mods. #2 is actually what I was trying to accomplish, but I did the pieces totally separately and hence wasn't quite able to line up the curve. I basically did the finial on paper. I should have taken better care to look at he fit. Your points are very well taken, and it gives me lots of food for thought for future finials. Thanks for your very clear and helpful thinking. ...Gary
A digital camera is also helpful
charlie belden
We turn with the piece horizontal - yet view the final results vertical. Things you don't notice on the lathe often jump out at you when the piece is in a normal viewing position - upright. If you use a digital camera and rotate the resulting image(s) so UP is up rather than Left or Right - things that ain't quite right often jump out at you - especially if you put a piece of white or light gray paper under things you're going to photograph. Minimizing background distractions makes the outline of the piece(s) much clearer.
Image editing software - like PhotoShop - can be great design refinement tools. Get a few images of the piece(s) in progress - taken looking as straight down as you can - and from the same vantage point if possible - and stick them together in PS - on separate "layers" so you can tweek them independently. You can then tweek a copy of the parts and print results you like. It's a lot easier to turn something - when you've got a printed image of what you're after near the lathe - or on it.
excellent idea...
Garyg in Md
Thanks Charlie. I appreciate your very constructive comments. ...Gary
Transition Details Illustration.
charlie belden
Meant to edit my earlier response - and apparently deleted it. Illustrated two "finial to piece transition" approaches - but didn't get into the details of HOW when going for a smooth transition that carries the curve of the piece to the finial.
I found an illustrated example I did in response to an earlier piece posted back in Februrary of this year. It shows how using a "stepped tenon" on the bottom of the finial avoids a "knife edge" potential problem you can have if you don't use a "stepped" tenon.
Takes a little more work - but the results are better.
