REAL MILK PAINT
finish on ebony?
finish on ebony?
finish on ebony?
Garyg in Md
Or not?
I just turned my first real ebony -- a finial.
What do I do next? Just sand and polish it, or put on some kind of finish?
Thanks, Gary
BTW, I was disappointed with how "chippy" the stuff is. I was expecting a "nice" turning wood, but even with a very sharp tool and good technique, I found it less than pleasant to work with. I had to take extremely thin cuts at the highest lathe speed I've ever used to get a decent result. Comments?
Re: finish on ebony?
Rob Wallace
Rob Wallace
From your description, you have indeed turned ebony - it IS quite "chippy", although once cut nicely it sands very well. My solution for finishing it was to seal first with a 1 pound cut of ultra blonde shellac as a sanding sealer, and then spray on a lacquer finish after taking it up to at lest 600 grit.
I have had ebony finials crack and break-off, and no longer use this wood for that purpose. My FAVORITE wood for black finials is African Blackwood (Dalbergia melanoxylon) which turns beautifully and takes detail much better than ebony will (at least in my experience).
Alternatively, you can use hard maple to get a similar effect, and then 'ebonize' the maple with a black dye. I use Fiebig's (sp. ?) black 'USMC' boot dye to blacken the finished maple, and then spray lacquer over it to finish the finial and seal-in the dye. Works extremely well.
IMHO, you probably will want at least some finish on the ebony. Without finish it appears somewhat dull - unless that's the effect you're after.
Rob Wallace
Richard Allen
Richard Allen
Chipy? Ebony is funny that way. Part of a board can be brittle and part can work great. Ebony sands better than any wood I have ever used (well maybe holly sands as well).
No other wood works like ebony or looks like ebony.
Why do we select the woods we select?
Jim in Burlington Ont.
Jim in River Oaks, Ont.
I use a lot of ebony in my furniture as accents, also in my pen making, I never apply a finish. I sand through the grades up to around 1000, then I buff with white diamond and then a micro fine abrasive used for fine scratch removal, also a buff.
Take care,
Jim
No fair getting help on the ebony Challenge
Tim Aley
thanks, all...
Garyg in Md
I decided to take a minimalist approach for starters.
I sanded to 800 and Abralon'd to 4000, followed by Ren. wax.
Perfect. Just what I wanted -- a nice satiny sheen. No other finish is needed.
(It does, indeed, sand very well.)
Per Tim's comment, this is for an MCW "Ebony Challenge" -- due Thursday evening. I blatantly stole a Keith Burns finial shape that I have always liked -- his simple, "modern" form with a low bead and slanted top. I'm happy with the result. I'll try to get a pic out soon. ...Gary
