I just saw an ad for a Grizzly G0462 for around $525. It has 16" swing, the spindle will fit all of my 1 X 8 TPI faceplates, etc. Does anyone know anything about this? Looks to be in my price range, but don't know much about Grizzly's. TIA.
Don, the tail stock looks like the weak link with that lathe. There are smaller lathes that will give you more bang for the buck. If you really want to turn things that get close to the 16" swing or even anywhere near that, you would be much better off saving for a Jet 1442 or 1624 or looking for a used lathe on line. In the end, you'd probably be much happier. It won't help you with the tools (chucks) you already have unless you go with newer jet mini line up or Rikon.
Like the previous poster stated that tool rest not looking too strong. I do not like the tool rest much. Also slowest speed is 600 RPM. If you want to take trees to bowls that might be tad fast.
Have you looked at the new Delta 46-460 EVS model which sells for around $599 at most places unless goes on sale. Yes, it is a mini lathe but lots of positive comments and better re-sale value. The non-EVS model is much cheaper.
If you must have 16� swing the Jet 1642 with EVS much better lathe. Yes would have to update your faceplates. Would not hurt to get a chuck with proper insert too.
I've owned one for a couple of years now. While it is adequate for my talents at the moment, I wish that I had invested in one with electronic variable speed. With a brand new belt, I can get the speed down to about 520rpm, which is still much too fast for good sanding. Also not great for the eccentric work that I'm fixated on at the moment.( Right now I'm waiting on a quote from my U.S. Bearings rep to upgrade to VFD.) It is a tough lathe though and has put up with a lot of hard work. I had to pull the tail stock apart and rebuild the rear portion after a lot of high pressure drilling work in metal. I wore out the flange that the retaining screw sits into. The motor seems to run a bit hot for my liking, but I put an auxilliary fan on it that blows across it and have had no problems. The guard on the motor is very hard to get on and off, but with a little judicious trimming that bug is fixed while keeping full functionality. One other thing I just discovered is that the locks for pivoting the head engage on the opposite side of the lathe. So if you want to turn large items, you have to have room to work from the other side of the lathe. Had I actually known more about turning and how much I was going to enjoy it, I probably would not have bought this model.
Actually, the 46-460 has a 12 1/2 inch swing, suitable for most things, it's variable speed, reversible and has a 24 point index... Except for the fact that it's physically small, it will turn a nice sized piece of wood and it's STURDY in every direction.
I have a Powermatic 3520 and the 46-460 is going to be my "demo"/backup lathe. AND, it comes with MT2 and 1/8TPI spindle.
