how much air would an air pump pump...
Garyg in Md
I'm tired of using a straw to blow the shavings out of a hollow form and ending up with some in my mouth or elsewhere. Time to get a compressor. It has to be VERY portable. I want the absolutely smallest and lightest one that will suffice to periodically give a couple blasts strong enough to get the shavings out. Nothing more, nothing less. So what kind of "size" do I need? (pressure, capacity, etc.)? Thanks, Gary
Re: how much air would an air pump pump...
Leo Cuellar
Leo Cuellar
If you just want to clean shavings out of your turnings you might try using an old fireplace bellows, until you decide on what compressor to get. I have a small Grizzly G0468 1.5Hp 1.5 gallon oil-less compressor that has been holding up really well. About $110, not a lot of capacity, but good for those little jobs, dusting out motors, pumping up low tires. You won't be able to run tools with it though.
Mike Mills
mike mills
If you do a seach for "pancake compressor" you can find new Campbell Hausfeld for about $45 and up on ebay or web sites. I bought a Bostic for my son about 20 years ago and it is still going strong. Most will go to 100 lbs but they are only 1-2 gallon.
Diaphragm compressor = NOISE
Doc Green
Be aware, a diaphragm-type compressor is extremely noisy. They're OK for outside, but in a small shop, the noise is, for me, intolerable. ~Doc
Walt Bennett
Re: Diaphragm compressor = NOISE
Walt Bennett
I've an old one of those that won't die (much as I want it to). A friend picked up a new contractor style twin tank diaphragm one that is amazingly quiet - just about the same as a belt drive two stage with mufflers. I'm still not getting either kind unless I can hear it running first though.
Richard Allen
Richard Allen
The pump for a vacuum chuck can be used as a small compressor also. So if you have a vacuum chuck system then you might get double duty out of the pump. If you have been considering a vacuum chuck this could be the start of such a system.
I second the discussion about noise. I would want to hear it run. I have a Campbell Hausfeld Compressor with a 1 Gallon tank that came from Harbor Freight and cause about $70. It will run a smaller brad driver or blow up a tire, but it takes it way too long to reach its cutoff pressure. It is very loud and annoying.
Two things, If you want it, I will give you the little one I mentioned. (I see you are in MD and I am near Chester VA.) I have three other compressors. I bought one of the pancake ones because the little one is entirely too small to run nail guns.
The second thought is for you to think about this carefully. Having a compressor opens up lots of possibilities. You could get nail guns. You could get a spray gun or air brush to improve your finishing techniques. Once you have one, you will think of many uses for it. So, consider getting one big enough to do other things.
Coyne
Switch your shop vac hose to the exhaust port and it will blow the chips for you. Still a nuisance, but you probably already have one.
Coyne
Thanks all...
Garyg in Md
I appreciate the very wise and to-the-point comments. I had an inkling about the noise but hadn't considered how bad it can be. I certainly don't need that.
Barry, I appreciate your offer, but the noise level sounds like a problem.
Coyne, I thought about reversing the vac. I like that idea. Where do I get a reducer and nozzle? ...Gary
Re: Thanks all...
Stuart Johnson
Turn one :D
Re: Thanks all...
Coyne
I got mine at either Home Depot or Lowes, and a 'crevice tool' also makes a good nozle. Coyne
Re: Thanks all...
Garyg in Md
Good thinking. Thanks. ...Gary
Air comressors
bill Crommett
I have a belt driven compressor that I bought some 30 years ago as a return to a sears store.. About five years ago It started making noises like the piston is trading cylinders with the other valves or something, so I bought a new Oil-less compressor to replace it. The noisy thing was so loud that I put it out in the barn to inflate tires and such where the noise wouldn't be too objectionable and figured that as soon as the belt pump expires I would get a new quiet one. Go figure, but the old pump still sounds like the piston is coming through the side wall of the cylinder, but it still puts out 90 psi and blows shaving all over the place.
If you decide to run a pipe to another part of your shop, do NOT use PVC pipe, it will burn your shop down.
Jorge Casta�eda
Gary,
I got a 2HP Hitachi, made in Italy! for $170.00 weights about 60 pounds, so is quite portable and has enough power to drive 16 penny nails at 120 pounds presure. I bought it for carpentry jobs and at some point we had half a dozen nail guns operating from it concurrently.
I think t was a good buy, now it mostly blows shavings out of pieces and helps to keep the shavings mess under control.
This have anyting to do with a Wood Chuck?
Al Kapocius
Re:Gary- don't overlook the Shop Vac...
JamieDonaldson
..option, and a piece of aluminum tube on the hose end that is small enough to suck out shavings rather than blowing them all over the place. Of course a compressor is useful for many other jobs, but don't buy one so small that you will outgrow it's capacity for other uses- you can never have too large a compressor, unless it's free!
Re: Air comressors
Garyg in Md
Bill, Thanks for the info. Please enlighten us -- how does the use of PVC pipe lead to a fire? ...just curious... ...Gary
Garyg in Md
Thanks Jorge, I was hoping for something smaller, lighter, cheaper, and quieter -- I may try to go with a reversed vac. ...Gary
Garyg in Md
Thanks for your thoughts, Jamie. As you may remember, I turn outside on the back patio and have to lug EVERYTHING in and out every time, so it's already a PITA. Having one more thing to lug around and store is not what I had in mind unless it's really easy. Based on the comments in this thread, I've decided that a compressor is not what I want. The use of a vac, one way or the other, is attractive. I usually take one out anyway, for cleaning off the lathe before I bring it back in, or sucking up walnut remnants that I don't want getting into the lawn. I'll rig up a small nozzle.
Thanks, Gary
