Deconstructing a bowl?
Carole Valentine
How do you do it safely on the bandsaw? I would like to cut a fairly large bowl into sections, some of them a curved cut, but I have never done it before and I have a rather healthy respect for the bandsaw so I thought I would ask for advice before attempting it. Have no desire to end up at the ER on a Saturday afternoon!
Re: Deconstructing a bowl?
Jim in Burlington Ont.
Jim in River Oaks, Ont.
I made a sled for my band saw a long time ago, I use it for many types of cuts I could not safely make on any other machine. What I also like about the sled is that it keeps my hands well away from the band, and I secure the work piece with clamping or a second fixture. Look at making a sled for your band saw and go from there, making fixtures for bowl section should be easier and more repeatable after that.
Take care,
Jim
Second the sled. My personal preference is for a sled that will have a runner in the miter track - that way there is no danger of slipping or sliding.
Lyle Jamieson
Lyle Jamieson
Sled or not the trick is to keep support right under the cut. If you have a cut going on with air under it then a nasty catch can suck the wood and your hands into the blade.
Betty Scarpino
Betty Scarpino
I regularly cut odd shapes using a bandsaw. Lyle's advice is to be kept in mind, for sure, but if that's not possible because of the kind of cut you want to make, then you can fashion a quick jig out of thin plywood, hot melt glue, and wedges. Make sure there is a wedge glued onto your bowl at the entry point of the cut and the exit point. The wedges should also be glued to a small "sled" of plywood. The wedges help support the cut. The hot melt glue usually peels of just fine (but if it doesn't, heat it up with a hairdryer, the scrape it off).
I also sometimes use masking tape wrapped around a round piece affixing it to a sled of plywood. In addition to the tape, I glue wedges to support the voids. Hot melt glue the wedges to the sled and to your bowl. I've cut a 10" diameter sphere half using this method. At first it seemed quite scary, but because we used plenty of tape and lots of wedges and hot melt glue, the cut was smooth and safe.
And of course don't put your fingers in front of the blade, ever, even far away. Keep them to the side. Good luck!
Carole Valentine
Thanks, everyone. Betty, your method appeals to me the most...hot glue, plenty of wedges on a base, etc. I can deal with that. Seems the easiest and safest way. I have seen what a bandsaw can do to unsupported wood and have no desire to experience it first hand so that's why I asked. May not get my nerve up to do it today, but it will get done. :) I may even decide to do it with a coping saw. More work, but I've got time...
Betty Scarpino
Betty Scarpino
The first time I cut a bowl apart, it took a lot of "working up to it," but once I made that first cut, a whole new world opened up. If you begin with a small bowl (maybe something that's headed for the fire pit anyway), you'll realize that it's actually quite easy and safe, given enough tape, glue, and imagination. Try it!
Carole Valentine
Oh I'm going to do it..eventually! LOL Going to have to if I want to make the piece I want to make. Will let you know what happens. Thanks, Betty.
Great Information
Barbara Gill
Leo Cuellar
Leo Cuellar
I agree the bandsaw is very scary for what you want to do. I would put on a blade with lots of little teeth, it won't cut nearly as aggressively, and will be easier to control.
Another option *LINK*
There have been some fantastic information given so far. However there is another alternative. Better in some ways not as good in other but safer no matter what. Try an Air Body Saw. You can buy them at GRizzly, Enco, Harbour Freight, Northern Tools etc. They are inexpensive, about $20 to $60 depending on where you buy them and if they are on sale or not.
Replace the blade with a wood cutting blade. This things cuts through bowls like butter. It does hog air but you don't cut for very long so most compressors can keep up. It's a little obnoxious at first but make a few trial cuts in some hardboard or 1/4" plywood and you learn to control it very quickly.
The down side is it's harder to make a really clean straight cut than a bandsaw. Curved cuts are very easy.
Dremel also sells a small jigsaw sort of attachment. I haven't tried one yet but have heard they work pretty well. I got this idea from Frank Sudol. He used a small electric one sold by Micro Marc tools. I was going to order one and found the Air Body Saw on Harbour Freight and picked it up. It works great.
http://www.grizzly.com/products/Air-Body-Saw/H8214
Lyle Jamieson
Re: Another option
Lyle Jamieson
I use a body saw all the time. I leave the hack saw blade in for cleaner cuts.
Re: Another option
don lewonczyk
Harbor freight has the air body saw on sale right now for $12.99 item91753-1vdh. Limit one, blade sold separately good thru 10/28/10. Regular price is$29.99.I don't know if you need the coupon or not but the bar code is 97696843. Good luck.
Terry Scott
Hot melt glue some support pieces around the bowl
Re: Another option
Carole Valentine
Don, after looking at the reviews, I think I will pass on this one. ;) If I turn the bowl to about 3/16 I can probably use my Electro-file with a good jigsaw blade in it.
Dozuki
Jorge Casta�eda
If it is that thin, one of the japanese saws willdo a fine job.
