Have a question? Ask Woody!
Battery Charger - Woodburning
Stuart Johnson
I'm trying to find the .pdf file or url for building a woodburning outfit using a battery charger. The search here is giving me a bunch of hits but I'm not able to find the one I want. The one I'm looking for shows step by step just how to make the modification plus there is a way to do it without ruining the charger for it's original use. A url or link on making a pen would also be helpful.
Thanks,
Stuart Johnson
Red Oak, Texas
Re: Battery Charger - Woodburning
Rob Wallace
Rob Wallace
I believe this is the link you may be looking for:
http://www.svwoodturners.org/TipsTricks/PriddleStyleWoodVaporizer/PriddleStyleWoodVaporizer.html
A very well-done how-to page... kudos to the authors and to the Silicon Valley Woodturners for making this information available.
Rob Wallace
Stuart Johnson
That's the one. Thanks.
Ken Vaughan
Ken Vaughan
Just finished one of these with a NAPA battery charger. I mounted the variable switch and the the two banana plug recepticles into the front of the case -- took a good look and then put two banana plugs on the battery charger. On the NAPA charger, the cord with the white stripe is to the read clip and I kept the white line is red convention with the plugs.
Figure I now have a battery charger if I turn the switch up all the way and plug in the clips -- or a wood burner with 6 or 12 volt power supply and a variable output.
