Sliding Dovetails
RPE
I got some inspiration from all these "Bowl from a Board" postings. I want to join my boards using a sliding dovetail as shown in one of the links.
I need to know if there is some trick to it or is it just trial and error to get the fit, and level (face of boards) of the joint. It is easy to make the way down the center of the edge of the board, but to cut the tail in the center of the other board (at the proper width) is a different story. To center the tail you have to cut both sides of it or it will be offset (during the refining process of the fit). So is there a trick or do you just try to get it as close as you can and then run it through the planer until it is flat?
Thanks
RP
