Exploiting An Unexpected Opportunity *LINK*
charlie belden
In turning, it's usually the wood that hands you an unexpected opportunity to exploit
- small knots which if positioned in the piece just right
- interesting spalting you didn't know was there 'til you got to it
- heartwood next to sapwood in just the right place to make the
contrast add to the piece significantly
- a heavy figure in what seemed just another chunk of wood
- a bark inclusion - that looks sort of like a horse head
This time it was a servo - its arm jerking around - linking to a darting
around eyeball - in another of my Wild Hare Ideas pieces. Micro
Controller, plus Servo, plus Ping Pong Ball "eyeball" can lead to some
Wild Hare territory.
Seems a servo arm jerking around can impart movement to whatever
it's fixed to. And if you put a little lead weight on the end of the
servo's arm, you can amplify that movement - in this case, to the piece
in whch the servo driven, darting eyeball is to be housed. And if the
bottom of that piece is rounded some, so it can rock and roll . . .
The "capsule" for this piece ,"Houston - we have a problem.",is now turned. Still need to thin down the bottom of the "lidded box with finial" and cut the hole for the eyeball to look out of - but I had to tape the servo inside to see how it worked - without the eyeball.
When the "darting around eyeball" was loaded into the micro controller that runs the servo - the piece rocked a bit every once in a while - when the servo moved the arm quickly and over a larger sweep angle.
Hmmm . . .
If I were to add some weight to the end of that servo arm . . .
First I filled some shrink tubing part way up with birdshot and
shrunk the other end to the servo arm. Got a little more
movement of the capsule.
Hmmm . . .
If I were to turn a lead fishing weight down - with a finger on
one end to attach some shrink tubing - and slip the other end
of that shrink tubing on the servo's arm . . .
Did a quick and dirty YouTube video of where I'm at with this
piece.
Comments, questions and suggestions welcomed
Hype Quick & Dirty vid of dynamic piece
Re: Exploiting An Unexpected Opportunity *LINK*
Dennis Ford
I have been watching your exploration of electro-mechanical additions to wood turnings and hope you keep it up. This is very interesting.
charlie belden
Once you get a little familiar with playing with these micro controllers and the stuff you can control with them, ideas for "behaviors" pop into your head regularly - sometimes unexpectedly.
What I hope I can get acrossed with the pieces I post here is to show just some of the possibilties - and provide enough info on where to get stuff, how to set it up, basics of programming "behaviors" - and using them. If I can make it easier for The Next Guy, maybe others will start playing with movement and sound and light - and sensors - that react to changes in their environment - rather than Just Sitting There.
So far, turning the "space capsule" has been the hardest part of this project. When you turn a lidded box with tapering sides you've got to get the lid fit FIRST, then do the tapering and hollowing. So there's a lot of chucking and unchucking and reverse chucking. And because the only dry wood I had big enough for the capsule was some "died and dried standing" spalted birch, the wood was a PITA to turn because it tore out horribly and in some places actually crumbly. Didn't matter how sharp the tool was it tore out and crumbled. Even stabilizing it with CA glue barely helped. Had to resort to my 60 Grit Gouge ; ). And getting the bottom rounded just enough that the box could rock fairly easily - but always right itself - was a long and semi-tedious trial and error process. I wanted low primary stability but high secondary stability (think canoe or kyak - tippy trying to get into it - stabile as hell once you're seated).
These early exploratory pieces aren't very refined or aethetic. They're more Proof Of Concept pieces. But I hope they demonstrate some of the possibilities of adding "behaviors" to pieces using accessible and relatively inexpensive modern technology. And if I can make it fairly easy to try using this stuff - maybe others will - and use them much better than I can.
