Man, any wood turning gallery would be glad to have the entries in the turning and burning. Fantastic work. The judges have a their jobs cut out for them. It will be interesting to see the winners.
I'll go through and pick mine to see if I can out guess them. Mine will be near the bottom based on what i saw. It was a lot of fun building it. I like to have a challenge like that. I think it makes you grow and often leads to a piece you can be really proud of.
I urge you to take up the challenge on the next competition or try out one of the AAW competitions. You don't even have to enter. Just use your brain and come up with something new and build it. it will be rewarding whether you enter or not. Who knows you might make something truely worth entering.
I had a ball making this but it did fight me. Just little things but I did learn a lot. I think it's fun when you limit your self the way the rules of a competition often do. This makes you think outside what you normally do. In this case I had been thinking of different things that I might try. I was hauling junk to the back yard and burning it when I looked at the book of matches. Bingo.
Clay: to anyone who knows John , it comes as no surprise that he would enter an innovative piece. While others have taken a style to great heights John is the most innovative and artistic turner on the forum. If you have forgotten John's cardiac clock, among others, go look it up. John: If you have read this please forget that I said anything about you. It is too bad that you have to work for a living.
I've known John for a long time, and agree that he is innovative and creative. I remember the Cardiac Lamp. It was a strong piece. There is a lot of Monkey See-Monkey Do work out there, but John always makes things that are his own.
Jamie I photographed the box and then used Free Transform in Photo shop to change the dimensions to fit size mirror blank that I wanted. Then I added photographs of the side of the box. I didn't like the other side so I took the first side and flipped it on photoshop. I place both of these next to the main cover. This was then printed.
I used epoxy to glue the photograph to the cherry blank, twice. The first time the epoxy ran over the edges and stuck to the blocks I used to clamp it. When I removed the blocks it tore the photo. I had to plane it off, resand, fill some voids, re apply a coat of epoxy to seal it and then glue the next photo in place. This time I left the photo borders on to help prevent bleed out and sealed the blocks with wax so the glue would not stick to it.
