I turned this small vase and decided to be a little fancy. My mistake. I sawed the top on an angle and now I have no idea how to reverse turn it to get rid of the tenon! I don't have a vacuum system, so that's out. Any ideas, other than grinding and sanding with my Dremel?
Make a jam chuck that will reach to the bottom of the vessel. make it a snug as possible fit for the diameter of the opening. to mount place on the jam chuck and bring the tail stock up to center. Then use tape(duct) or plastic electricians, or shrink wrap to secure the piece on the jam chuck. Finish most of the base with the tail stock up, then do the final small part with the tail backed away taking small gentle cuts. Piece of cake.
You got it John, I do this all the time with natural edge vessels. Just a 2 inch diameter dowel long enough to hold in the chuck and reach down and drive with friction on the bottom. Make a concave surface on the end of the dowel so it seats around the outer ring against the inside bottom. Use a leather pad or even thicknesses of paper towel to prevent the inside bottom from damage. No need for the tape. This will self center itself in the bottom, the tape would likely shift it off axis.
Ditto on all of the above. I just use my live tailcenter to hold it in place and turn down all but the little tenon left by the live center. I then carve that away by hand.
Here's another option. If you happen to have a bowl blank with a diameter somewhat larger than the opening in your vessel and deep enough for the rim to fit inside, mount the bowl blank on the lathe, true it up, and use it for a jam chuck. Turn a small radius on the inner rim of the blank so it doesn't dent your vessel. Thin padding is optional. This gives a very stable situation. ~Doc
A simpler way is to use a bendable flush-cut saw to remove the tenon. Just mask off the outer edges with masking tape so you can't disfigure the bottom, and reduce the tenon to a lower level, then sand it clean and taper the edges down with sandpaper or a file first. This works well if you've left an outer ring as design element, too. Just one more idea.
Don, don't listen to these folks. What you have here is a common situation in any shop called NeedNewToolitis. You are displaying classic symptoms...a job gone wrong, the need to consult with others despite knowing the true answer, that faint ringing sound from your credit card. Text book case. The cure is simple...get a new tool and in your case, a vaccum chuck system!
No charge for my advice or services. I'm just trying to help.
