Have a minor modification to make on the Eyeball Prototype shown in the video and have started turning the Capsule "box". The sloping sides of the box should present some "challenges" getting the lid fit right AND a continuous slope up the side.
There's a link to some more web pages on the piece the eyeball is for in the "description" text accompanying the vid.
That's pretty nice, twitchy side-to-side action, but it would be nice if there was a way to work in a little up-and-down twitching, too.
I wonder if it would work to have a gimbal-mounted eyeball with a magnet, or steel plate in the back, then control its motion by a twitching magnet just behind (or under?) it. Return to center might be a challenge to build in, though...hmmm.
I've seen a set up that uses a small universal joint attached to the inside of the eyeball - directly behind the pupil- the other end fixed to a vertical fixed support. Two servos, mounted behind the eye - at 90s to each other - each with a pair of connector rods - gets around the need for a larger gimble arrangement. I've got a U-joint from an off road RC car - but I'm trying to stick with K.I.S.S. (Keep It Simple Stupid) for these early dynamic/kinetic pieces.
The idea of using magnets to couple things - without physical connection - is a great idea. But I'm concerned about magnets around a micro-computer.
There are several electronic sensors that could be used to get the eye to track movement. They're not very unobtrusive though. I could use small resistors that change resistance based on how much light is hitting them. Could use a person's shadow with them to detect movement and direction. Perhaps that will show up in a future piece.
The "capsule" will have a curved bottom and the servo torque should impart some rocking movement to the whole piece. I have a small motor with eccentric mounted weight on its shaft that vibrates - like those vibrating "coasters" restaraunts use to let you know your order is ready. Building one into this piece wouldn't be difficult. Intermitent virbrating could be interesting. . .
I'm just beginning to work with some of the "behavior" options micro controllers add to the creative pallet. I'm coming at this in small discrete increments - to make debugging and prototyping less complicated. Once I've got the basics of several of the possibilities I can start combining them - light, sound and movement. Subtlety and aesthetics hopefully will come in time
I agree that it is a bit disturbing to have a "thing" track you as you move, however, it might be just as unsettling to have one with an eye that refused to look at you, no matter where you positioned yourself!
A shy turning! Interesting idea - to have the piece turn AWAY from you. Title it "Greta Garbor - I vant to be alone.".
Or maybe a piece titled Paparazzi - a strobe going off makes it turn away - and maybe cover its face - and run. - or try to punch you. The FLASH activated Turn Away behavior would be easy to do. And it could really freak out someone trying to take a picture of the piece - using their camera's flash. Hmmmm . . .
See what I mean about opportunities adding a "behavior" to a piece might have?
