Which do you do first - the hole or the outside?
It doesn't matter as to the actual "piece". Be it salt shaker, peppermill, candlestick or whatever.
I usually drill the hole and then use a live cone center and a jam chuck to turn the outside. I figure that way, I'll always have the hole in the exact center of the piece. I guess the pen turners drill the hole and then turn on a mandrel - so that is sort of similar.
So - when would I want to drill a hole after turning the outside? I'm reasonably happy drilling the hole and then turning the outer portion.
TIA.
Re: Which do you do first - the hole or the outside?
Barry
Maybe whre the hole would be fairly shallow and not apt to wander away from the center?
Steven Antonucci
Actually, I use this in my class
steven antonucci
We turn a candlestick between centers first, and then drill the hole using the headstock to turn the taper hole first, and then the bottomside if you want to counterweight it. I think it's a lot easier for a beginner to master doing it this way because they only need to get the point of the forstner bit in the center point hole and it automatically centers.
Next, I teach them how to make a mandrel. Usually, they don't have enough tool control to size them accurately,but they get the concept. Universally, they think that they "hole second" method is nearly idiot proof and works without any special skills.
I had to figure this out during my class to overcome a bunch of candlesticks that hadn't been drilled first, and we ended up doing all of them hole second...
S
Re: Actually, I use this in my class
bill crommett from Seneca
Depending on the length of the hole. In drilling a long hole there is a tendency of the drill to follow the grain and the hole will come out the side of the piece. In making a long, long hole for a lamp cord I have found it best to split the spindle stock and route a groove for the electric cord, then glue it back together and turn the spindle.
