update on turned and burned project.
Well as usual if you wait until the last minute everything that can go wrong does. I'm gluing a photo to wood. done that many time. This time the glue seeped around the photo and bled onto the blocks holding it down. When I removed the block it peeled up part of the photo. Had to hand plane all of that off and start over.
There is another part that needs a special epoxy mixture to produce a sort of Styrofoam looking epoxy. Well apparently the amount of colorant you put in is very critical. I tried 3 times and it failed to harden. The 4th time was more or less a success but has a bunch of 3/16" and smaller air pockets. So I had to cover it all with wood putty and will have to carve in the texture and airbrush it. Should have done that to begin with.
Anyway if all goes well and I don't screw up the texturing, air brushing, pyrography and final assembly, I'll be able to shoot it Thursday and actually enter this competition. I don't expect to win with this but it's sure been fun and will help move my hand mirrors to the next level.
