If you haven't had a chance to flip through the latest edition of the American Woodturner I encourage you to do so. It's a fantastic issue. The article about the Wyoming clubs outreach to kids and the article about the club in Georgia helping the veteran soldiers find a life long hobby are wonderful. I also encourage you to read Russ Fairfield's article on the skew chisel. It may be one of the best I've read. Great job on this issue to everybody who contributed!
Lots of eye candy in this issue. Betty continues to showcase amazing artwork and put it perspective, but she serves up some interesting techniques, too, like the Huichol bead work. As for basics, I savored Russ's skew article. Can't wait to get the right tools and practice some of those techniques. I looked for some mention of grinding angles and/or included angles, but I couldn't find them -- might have missed it.
Sorry Ellis, I missed that one on blade angles while writing it.
The oval skew is the same shallow angle that it comes with from the factory and I have never measured one of them. I have no idea what the angle is, but do know it works well.
It will always be true that the lower the angle the lower will be the cutting forces, and the less will be the tear-out of the wood grain. Skew chisels aren't much different from plane irons and wood chisels when it comes to making a good chip and and a smoother surface on the wood. They all like shearing cuts and low angles. The only real difference is that the wood is spinning.
I grind the normal rectangular skew to a blade angle where the width of the bevel is almost 2X the thickness of the blade. I have never measured one of them either, but that angle works well for various blade thicknesses and a lot better than the blunter angles that come from the factory. Also, the concave bevel from the grinding makes a thin blade edge that can be honed to very sharp.
Don't be afraid to ask a question if there is anything that was left out or not explained well enough. Thanks for asking.
Ellis I've played with the sharpening angles quite a bit. I've found the shallower angles require less force to use and give a cleaner cut. I have had the same problems you have with plane irons on really figured wood. Sometimes a flatter angle simply cuts with less tearout on these.
I think a 35 to 45 degree bevel seems more forgiving to kickback when turning beads but that may just be me. I think it may be because the 25 degree tool cuts so easily it's too easy to over rotate it and you come off the bevel.
On my tools a bevel that is 2x the thickness of the steel is about 35 to 40 degrees.
I only measure my tools because I get that question every time I do a demo. I also was confused by the angles when reading articles. I saw Mike Darlow's article on the skew and he recommended 25 degrees. I wasn't sure if this was an included angle or some other measurement. I made one and tried it. It does get really sharp, easily, but it requires a delicate touch to use for anything other than planing cuts where works extremely well.
It's my birthday today -- what a lovely present to wake up to! Thanks Jen (and everyone else).
It was a pleasure working with all the authors who contributed their stories and knowledge. Russ was ever so obliging when I sent him a message asking for beauty shots of carrots and rutabagas. I'm fairly sure he had to buy more veggies to accommodate my request.
The two people I work with for design and layout (Jaime and Linnea) are excellent at what they do and they're also a lot of fun, which makes my job even more enjoyable.
The advantage to turning vegetables is that I could buy a few extras and get some good healthy eating from those not turned for the article and pictures.
