Vacuum Chucking
Vacuum Chucking
Vacuum Chucking
Tomm
I am thinking about buying a pump that I could use for both veneer work and also vacuum chucking. There seems to be several types of pumps and I was wondering what type most of the turners use. Thank you for any help you can offer.
Re: Vacuum Chucking
Re: Vacuum Chucking
Fred Holder
I purchased my vacuum chuck from Craft Supplies USA several years ago. It has done a very satisfactory job of holding bowls on the lathe for turning off the foot. I think they still carry the same pump. I do recommend using a guage and a bleed valve, if you turn thin vessels.
Re: Vacuum Chucking
Re: Vacuum Chucking
I have a vacuum pump a friend gave me. Its a smallish Gast pump that moves about .8 CFM. I use it for vacuum chucking and am sneaking up on Veneering. I think this pump is adequate but on the small side, especially for chucking. More CFM would be valuable for pieces that don't seal perfectly.
I suggest you go to the Joe WoodWorker site and Read until your eyes bleed. More than you ever wanted to know and reasonably straight forward.
Re: Vacuum Chucking
Re: Vacuum Chucking
Jeff Willaford
Gast seems to be a fine brand. I bought used but in good working order. I have one that is rated at 10cfm and I would think that's fine for veneer, or any other vacuum press, work. Continuous duty rated, oil free. Check 'Carl Ford vacuum chucks' with your favorite search engine.
Re: Vacuum Chucking
Re: Vacuum Chucking *LINK*
Doc Green
I have a Gast 0522 which is rated at 4 cfm and 26" Hg and it does fine. Unfortunately, The Surplus Center no longer supplies them (to my knowledge).
However, the Stubby Lathe people now sell a vacuum pump for turners that looks to be pretty good. For more information, go to their site and then click on on-line store.
~Doc
Stubby Lathe Usa
Re: Vacuum Chucking
Re: Vacuum Chucking
Carole Valentine
I use a Picolino VTE 3. Has a flow rate of 2 CFM and a continuous rating of 25.1" hg. Works great for me. The thing I like the most about it is it is small in size and very quiet - 55db. Have no idea what they cost or where you would find one - mine was given to me by a friend who rescued it from his workplace when equipment was being changed.
