Gluing veneer to PVC Questions?????
Watched a Turning TV show on a local PBS cable channel. First time I've seen it. I am up for a good turning show, but I am not terribly impressed with this one, but I am withholding judgement until I see a few more.
The guy was making a Christmas Ornament out of a cardboard mailing tube. He cut a short piece of tube, covered it with veneer and turned a decorative top and bottom and an Icicle. I was wondering if a piece of PVC pipe might not make a suitable tube? If so, What glue would you use to glue veneer to PVC?
Re: Gluing veneer to PVC Questions?????
Don't see why it wouldn't work although I would just drill a hole in a piece of wood and mount the holes between some centers and turn the ornament. You could also mount a block in a chuck and drill it and then turn the outside.
To answer your question. I think Contact cement would work well. I've found epoxy doesn't stick to PVC all that well unless you rough it up with really course sandpaper.
Don at Central Illinois
I think the best would be contactd cement. Just my .02 but I've never tried it.
Russ Fairfield
My experience is that PVC pipe makes wonderful vacuum fixtures because nothing other than a a glue for PVC pipe or Acetone sticks very well at all.
They work because they melt the pipe to make a good glue joint with another piece of pipe. If you are satisfied with their adhesion to the veneer, you can use them.
Mike Jones in Redding Ca.
I would try 3M spray adhesive. Should be good enough for something like ornaments.
Scott Hurley in N VA
I'm not sure I would try PVC at all. It seems to me that PVC pipe inside the ornament would make the ornament fairly heavy - it would probably need a strong branch to hold it up. Just my $.02.
Scott
If you try the 3M use the Super 77 not the 75. Spray both parts one or 2 times and then stick them together. It's pretty good stuff but I'm not sure it's any stronger than good ole contact cement.
Barry Why not try toilet paper roll tubes or paper towel tubes. The are about the right size and lots of glue will stick to them. Once you put the lids on they will be quite rigid.
Re: I'm with Scott in this situation,....
JamieDonaldson
....because by the time all the tube cutting and veneer gluing was done, you could have turned 2 all wood ornaments. There would not be any apprehension about glue failure, design handicaps like no bottom for an icicle, and it would be much lighter in weight.
Jim H
Please understand the following opinion is from someone that has pretty much only turned shavings so far.
I think the point of the project is to get a segmented look without the complicated layouts by using veneers and the pre-done veneer accent strips. I believe the cardboard tube is for its lightweight. You can find all sorts of cardboard tubes in the kitchen for free (think Parmesan cheese and spice containers as well as the paper towel tubes). Or the actual shipping tubes are fairly cheap for as many ornaments as you can get out of one.
Just my $ 0 .03 (inflation)
Thanks.....
I just did not like the look of the paper tubes, but maybe I should try them before I reject them.
I need some ideas for nicely cylindrical lightweight tubes.
90 is even better, but more $
Dick Coers
Re: Thanks.....
Dick Coers
If you want thin PVC, get the extensions for drains. It's really thin. I think if you rough it up a little, gorilla glue would work fine. It might be a little messy, but I don't like contact cement for the long term. You might also try making your own tube by rolling newspaper around a PVC pipe. That would add a "green" image for marketing.
Leo Cuellar
Wrapping paper tubes?
Leo Cuellar
Colin
What about using the pvc tube as a mould and laminate three of layers of veneer to it and make your own plywood? The inner veneers could be any wood and only the outer one something special.
Ric Taylor
I Found the Right Glue
Ric Taylor
My current turning project is three identical creamation urns with screw-on lids. Rather than threading the wood, I decided to try a different approach. I made threaded inserts from 2-inch threaded PVC pipe connectors, available at any hardware store.
The challenge was finding a glue that would hold the PVC inserts in the wood. I tried all sorts of glues and epoxies, but couldn't find anything that would really bond to the PVC.
Then one day I was in Ace Hardware and found that they stock two types of epoxies designed for PVC. One is a glue and one is a putty. I don't remember the brand name (I'm not at home at the moment), but they are in the section of the store where all of the different glues are stocked. I used the epoxy glue to attach the PVC inserts to the lid and body, and the grip is quite strong, there are no issues.
I experimented with the epoxy putty. It also bonds firmly to the PVC, but it wasn't the right product to use for this particular application.
I hope this helps,
Ric
Russ Fairfield
I agree with Jamie and whoever else said the same thing on this one. Think beyond the article and whether you want to make an ornament that is a copy or a personal design that will look better because you turned a shape to the tube.
You can make the tubes out of wood. You can buy a closet rod or a dowel. You can make it from a scrap of 2x4 construction lumber, and the cost is almost nothing if you have to buy one of them at HomeDepot or Lowe's. Or, you can use an old broom handle. You can turn and sand some curve and shape to the outside or leave it straight. They will be about the same weight as the cardboard when drilled and turned thin and to a similar diameter, and even lighter if they are smaller. A wood dowel with a shape will make a much better looking ornament and a smaller diameter may not require any drilling at all. Any glue will stick. Most important, they will look a lot better than painted cardboard.
Re: Wrapping paper tubes?
Dick Coers
I was thinking that you could basically make paper mache tubes if you wanted a thin lightweight substrate to glue the veneer to.
