A cautionary tale, Long
Mike Foster
I was out in the shop today finishing some rolling pins, coffee scoops etc. and decided to put another coat of finish on the mirrors posted below. I decided they needed a light sanding with 600 grit sandpaper first, and thought it was easiest to do this on the lathe. The smaller mirrors will fit on one of my jaw sets, but the mirrors that I did with the laminations had to be larger because the pattern of the lamination would look better that way. So I decided to use the Cole jaws, no problem.
Well, remember my post inquiring about set screws on an older chuck? I mounted the mirror and put the chuck on the lathe and fired her up. I quickly realized that I failed to check the speed before turning it on and realized it was way too fast for the Cole jaws. So my quick reaction was to reach for the speed dial and turn her down. Wrong move! Now this is really a foible of the fact that I am still settling in with the Robust. With my Woodfast, it would just coast and slowly lose speed till the speed met that set with the dial. The robust has electronic braking, which is really nice in most situations, but here it did me no favors. There was so much angular momentum built up in the Cole jaws, that they didn't really want to slow down, and you guessed it, the chuck started spinning off the lathe, even though it was still running. Things are happening so fast my only thought was to push on the mirror blank to add friction and help slow it down. Not enough, quick enough. It came off. Luckily I was standing to the side and it just grazed my hand as it started careening and rolling across the shop. Minor scrapes, no bruises or broken bones. Luckily the jaws, chuck and lathe seemed to escape damage as well. The mirror blank got a few dents, but I have already repaired them, so it came out OK as well.
So there are a few quirks in this mess that are really specific to my situation. One is that I love that Axminster chuck. Mostly because I can spin a set of jaws out and a new set in without having to mess with any allen screws. This is a pretty old chuck and worked fine with my Woodfast. It does not have a small recess built in that indexes it to the lathe, however. This wasn't a problem with the Woodfast as it did not have the little tenon on the headstock that indexes chuck and faceplates. So, I usually fill this space with a washer so the Axminster then has a good flush seat against the headstock. Since I was only going to do a light sanding and polish, I skipped putting on the washer. So now the chuck only has a small area of metal seating it to the lathe. Another problem was the mass of the Cole jaws. The other quirk was that I am still not programmed into the idea of the electronic brake, but you can bet I'll be more attentive now.
The real error was not checking the speed first. I am usually really good about that, but think I got in a bit of a hurry. I still don't think that I'll bother putting in a set screw on the chuck, as I probably wouldn't use it anyway. I have been reverse sanding with the chuck (but with the washer installed) with no problems.
Just a FWIW/FYI tale.
Mike
