Hunter 5 on end grain...
Garyg in Md
I should already know this, but I don't, so I'm asking...
I have a small, END GRAIN box elder bowl with a beautiful starburst of red ambrosia in the middle. The wood is dry, and it's very prone to tear out. I can't even shear scrape it (on the outside) without roughing it up. A real CUT is required. That's easy enough on the outside, but the method I use for hollowing on end grain is to stick the point of a spindle gouge in with the flute at about 10 o'clock and go from the inside to the outside. It works fine as far as removing wood is concerned, but I'm getting tear out on this piece. I don't have a hook tool or a Berger tool -- I guess those would be ideal.
But I do have a Hunter #5. So my questions is: will the Hunter #5 permit me to do a real cut on the inside of this relatively shallow, end grain bowl?
Please let me know if you've tried it. ...Gary
