Behavior Inspired Idea
charlie belden
Playing with micro-controllers and things you can stick on them and control has introduced BEHAVIOR as a design element - something I found difficult to do with a static turning. Once you have the ability to dynamicaly CHANGE something about a piece, design inspirations seem to pop up unexpectedly.
Here's yet another example that popped up while playing with a micro-controller. In this case it was controlling a servo starting with a free servo program I downloaded off an Arduino web site.
Playing with an internal light source and ways to get its light out where you can see it has lots of possibilities. Adding the ability to add controlled sounds add more possibilities. Adding sensors that can detect something and trigger an action throws is more possibilities. Now adding movement/motion makes even more things possible.
Having all these options permits incorporating a BEHAVIOR into pieces. And THAT makes for plenty of inspirations.
Here's another example.
Comments, questions, suggestions welcomed.
