I'm not famaliar with the Wahl Sander, but there was an article in Turning Talk, June 2010, Newsletter of the South Auckland Woodturners of New Zealand, titled
New Use for an Electric Toothbrush by Ross Vivian. I've obtained permission to reprint that article in the November 2010 issue of More Woodturning magazine.
Basically, the article recommends using an Electric Toothbrush with the bristles cut off and replaced with sandpaper. I haven't tried it yet, but is sounds like the ticket for some of those hard to get at places and would likely work well to do the sanding around the feet on your bowls.
The Electro-file I have found to pretty good...very thin sanding blade about 1/8" stroke. Also good for cutting away waste if you put some decent jig saw blades in it.
