New Hunter 3/8" tools *LINK*
I had a chance to use the new Hunter 3/8" hollowing tools today. They are really sweet. I wasn't sure about the tapered hook tool. With the cutter being flat in relation to the shaft I thought it would be grabby. It was at first but practice on a flat piece of wood before I put it into a hollow vessel solved the problems. With this tool you need to take a lite cut at the beginning of the cut and I found tilting the tool down a little helped.
The straight tool is incredible. I will use that one a lot on all sorts of smaller work. It cuts quick and is very easy to control. It doesn't have the vibration of my smaller shaft hunter tools.
The back cutting tool really solves some problems I've had with hollowing under the lip of vessels. I like it a lot. I'll be interested to see what other uses I can find for that tool.
I hollowed the vessel I was doing today to destruction. I had cut holes in the sides so I could see what the tools were doing and how they cut. It was difficult because there was almost no wood left. Trying to turn mostly air requires a really light touch. These tools let me do it.
I turned a small box shape vessel yesterday that had so many holes routed in it that it was like turning a jail cell. I was able to turn it down to 1mm thick. I shot it next to my cupcake for size comparison. When I get new tools I like to test my skills with them.
http://www.hunterwoodturningtool.com/products/no1_taper/
