Poly Fill
Is anyone else using the Poly Fill the Bill Hale sent out. I'm getting down to the dregs on bottles. It's interesting stuff.
The Plus side. It is easy to mix, I use electronic scales which makes it easy to mix small or large quantities accurately and quickly. I just use a dixie cup and measure out equal amounts.
It hardens extremely quickly. Turner (and I guess I'm one of them) want things right now. We hate to wait for wood to dry and even CA glue which dries really quickly comes with Accelorator. Poly fill starts to cure in just 45 seconds or so and seems to harden well enough to turn in a hour. I haven't tried it sooner but it's probably good before the hour. This makes it very easy to fill several areas on opposite sides of the piece in just few minutes. When it starts to cure and thicken you can spread it but you better be fast. Inlace works the same way but you have much more time to spread it.
The downside. It hardens really fast. You have be ready to fill right now, not in a minute or so. If you have more than one area to fill you might want to mix smaller batches and fill them seperately.
There are 2 parts to this. One is more or less white and the other is dark. The white one appears to be trying to crystalize. I've been able to mix some of it with vigorous stirring but today I had to dig out the big chuck and toss it which changed the ratio slightly. It didn't seem to affect it but it's something I need to keep an eye on.
It's not as hard as Inlace or Epoxy which is good when in contact with wood. It will flex with the wood. Unfortunately I don't have any long term pieces to know if this stuff holds up overy time.
All in all I think it's good stuff it's just different than epoxy and Inlace and needs to be used differently.
