I may be mad but I am not Crazy Burl Tree 4 Progre
Terry Scott
I have made three in this series and each customer that brought the pieces has been pestering me to make another I finally found some more branches with burls on about 6 months ago .
As they say you have to be in the mood
today was the day
So far 12 hours but I was having fun pushing my Boundaries once again
As you can see I only just had clearance to turn this sucker
The time is in each set up ,some would say why not just carve the thing,but that is not my thing If it can fit on my lathe Ill turn it
Counter balance is important and making sure the straps are tight as I turn these just on the fast side as the cut is easier
So you can call me mad if you like but I am not crazy as you can see this is the forth
One thing I dont have to worry about soon is someone plagiarizing L.o.l
Re: I may be mad but I am not Crazy Burl Tree 4 Progre
Steven Antonucci
I can't imagine how you'd get enough strap tension
steven antonucci
to safely hold the piece. I assume the 2x stock propping it up is screwed into the burl log in areas you will carve away?
You are pretty safe from being copied. None of us would even want to be in the same room with that thing spinning, let alone the guy at the lathe with the tool in his hand! LOL
Steve
Bill Blasic
Re: I can't imagine how you'd get enough strap ten
Bill Blasic
Terry,
Mad not crazy, fair enough! Just cannot imagine attempting this, amazing.
Bill
I am not sure about New Zealand, but
jake Niedling
I think Mad and Crazy would apply here in the USA. :D I am an engineer by training and just shake my head everty time I see your mounting. Very creative and enjoyable to see how you are doing it. I really enjoy your posts and glad you share it with us here on Wood Central.
Jake
Safety Attire?
Al Kapocius
Presume that you wear prespotted polka dot shorts when turning.
Al Kapocius
Re: I am not sure about New Zealand, but
Barry L Elder
Bodacious!
Terry One of the first turners I learned about after I met John Jordan was Stoney Lamar. He was and I still is famous for his off center work that often doesn't even look turned. I remember he used a giant faceplate like you do and had chains, cables and straps bolted on to hold the pieces. He also used lead weights screwed on to counter balance everything.
I've only done it a few times over the years but never to the extent that you and Stoney do. I think you have taken it to the next level with the bowl and burl pieces. Those are really cool.
Re: Safety Attire?
Donna Banfield
Al, now that there is funny...I don't care who you are! (to quote a famous redneck cable guy).
Terry Scott
Steve The straps are that tight you can play a tune
To tension them I call it walking the strap
I just keep placing in tek screws towards the work and the screws tension the strap
The webbing is good to use as the screws dont pull through
The wedges are placed on to form a cradle
Re: Safety Attire?no
Terry Scott
No but they do have a few brown stains l.o.l
Terry Scott
Jake I have a set step plan and follow it religiously Every step is checked 3 times any doubt at all and I start again
My heart used to get a workout and Id grind my teeth but know I have done enough of this type of turning that the challenge is enjoyable
The enjoyment comes from designing new works were no man has gone before l.ol
Terry Scott
John one of the ideas I am working on is a large platter the face will be turned with hollow forms and small bowls to represent the moons surface
I had 3 pieces on the lathe so far and ended up with designer fire wood each time
I will need to turn this burl tree between centers after the bowls /trumpets are complete balancing that will be interesting
I should thank Rob Cadaye as I wouldn't be doing this kind of thing without my Stubby 1000
Just cannot seem to break the thing
Base wood?
What do you use? Obviously there are a LOT of screw holes in your face plate wood. I'm curious as to which wood you might use for all the repeated use.
Re: Base wood?
Terry Scott
Mdf I glue 2 20mm sheets together
If you use ply when the screw are taken out they peel off layers of ply
Leo Cuellar
Love it! Love it!! Love it!!!
Leo Cuellar
and I thought I was living dangerously trying my first 3 cornered hollow form last night. :D
Awesome!
Don Orr
"You are pretty safe from being copied. None of us would even want to be in the same room with that thing spinning, let alone the guy at the lathe with the tool in his hand! LOL "
I don't know about that Steve-I'd love to be there and see it in action and maybe even give it a try. I've never claimed to be entirely sane though.
Thanks Terry for the photos of how you do what you do so well.
