Re: LED Light Magnifyer For PM 3520???
Don Evans
I've tried many combinations over the last 30 years and come to following 2 conclusions.
1. It's best (for me anyway) to keep the light source and the magnification separate from each other, in other words not light and mag in same unit.
2. At this time in technology LED's aren't there yet, I find that the spiral florescent bulbs are still best at this time. Mostly due to fact that they are close to you and heat isn't an issue. Also you can use higher wattage bulbs therefore more light, it's also easy to change the wattage for different task.
Maybe if you spend enough money one could get the LED's to work well but so far I haven't found a unit that puts out enough light. I also don't like the blue hue as when working with colors.
Your mileage may vary, I'm using this mostly for carving. Using mags on a lathe can be exciting if you use them while turning so if you try that be very careful, I don't recommend it.
Don
