with the interest in coring in other threads thought this might be of use. I'm always uncertain just how close I am getting to the bottom of the bowl and forming yet another "custom funnel". The cutting tip of the McNaughton coring tool is an extension of the center line of the handle unless you have bent your curve. I took a piece of 1/4" aluminum flat stock. bent it 90 degrees. One leg is about two inches longer than the biggest bowl diameter I can turn. The other leg is the from the front of the handle to the tip of the tool. When I am coring and getting anxious. I stop the lathe leave the tool in the core. Put one side of the "diameter" gizmo leg against the front of the handle where the tool goes in. The end of the other leg will be above the cutting tip and shows where you are in the core. CHEEP and effective.
Steve, I'm not where I can do either right now. Picture a piece of 1/8/x1/4 inch flat aluminum stock. Bend it so that one leg is the length of the tool from handle to cutting tip. The other leg is about 2" greater than the swing of the lathe so you can move it up and sown. That leg is the one you hold flat against the front of the handle where the cutting tool goes into the handle . That portion of the handle is flat and the aluminum rests against the flat place. The major factor is that the tip of the cutter is inline with the center line of the handle so even a piece of rod bent 90 degrees would work.
