The mystery of the expanding hole
David Walser
I have a mystery I'm hoping you all will be able to help me solve. Yesterday evening, I prepped some bottle stopper blanks for turning. To do this I mount the square blank in my four jaw scroll chuck and drill a shallow recess in the tailstock end of the blank with a 1" Forstner bit held in a drill chuck mounted in the tailstock's quill. I then drill a 23/64" diameter hole about 5/8" deep. After preparing several blanks in this manner, I then mount my bottle stopper mandrel in the headstock, screw on one of the prepared blanks and start turning. (The mandrel I use is from Ruth Niles that incorporates a 3/8" X 16tpi tap for creating the threads. It's a great time saver.)
Anyway, here's the mystery: When I tried to mount one of the blanks I prepped last night on the mandrel, the mandrel's 3/8" stud/tap slipped loosely into the hole drilled by my 23/64" bit. The threads of the tap didn't even touch the sides of the hole when the blank was centered on the mandrel. Huh? This was the 2nd or 3rd blank I prepped out of five or six blanks. All the other blanks were drilled with the same bits (I never removed the bits from the drill chucks) and all the other blanks could be tapped properly. So, what happened? If it matters, the blank in question was African Blackwood (I think). The other blanks were from other exotics.
