Pulleys frozen onto motor shaft - How to move? *LINK*
Henry (Raleigh, NC)
In March of '09 I started the linked thread - about removing the frozen drive pulley from the motor shaft of my Nova 3000 lathe.
A year and a half later I have the same issue - the drive pulley set became misaligned over time, and it is "frozen" in place. Going through a number of belts finally clued me in to this.
There is a key in the keyway and the set screw is removed. I have used PB Blaster and wooden wedges in attempts to loosen it. I called Tim Geist the Nova service guy - the technician there suggested the route that I have tried (wedges, PB Blaster) and possibly heat.
The only ideas I have left to try are:
1. a gear puller. For this application the diameter of the center point diameter is too large to reach the shaft inside the pulley assembly, so I'd have to create a smaller diameter post to extend that center point. What I do not like about a gear puller is that it pulls up on the outside of the large pulley rather than pressuring the portion closest to the shaft.
2. heat the pulley (suggest by technician at Nova service center/TVGeist).
Any other ideas? The wooden wedges finally worked last time - but this time I have only managed to move it about 5 mm.
Thanks
