Hoarding or Potential Inspirations?
charlie belden
With the ever expanding number of Cable/Satellite shows about Interventions, they�ve finally gotten to a type of intervention I can relate to � Hoarders. And we�re talkin� people who have to climb over three foot stacks of old newspapers, mounds of clothes, piles of shoes, stacks of magazines, walls of boxes (no doubt filled with priceless treasures) � in order t just get to the bathroom or kitchen sink.
Now there�s a fine line between hoarding and �collecting� � sometimes seeing the difference is tricky � to everyone except the �collector�.
But what I�m interested in is surrounding oneself with things that MIGHT be able to be combined with other things � to create some new thing � that might be interesting.. The closest current term for this behavior is Mash Ups � taking �samples� from a bunch of different types of music � mixing them together to create something that seems vaguely familiar but identifying why may be quite vague, that all somehow goes together as something actually new. Some Found Art pieces work using this process of creation/synthesis. Assemblages are another example, though it may be just another version of Found Art.
Back in my jewelery making daze, I was visiting a designer/manufacturer of jewelry down in Carmel. I noticed he had quite a library of art books and oddly enough, catalogues of plumbing fixtures, vintage auto parts, airplanes, architectural elements and machine tools. More surprising, not one of his books was on jewelry.
I asked why these catalogues were in his library and why books on jewelry were conspicuously absent.
His response � �Inspiration son. These books are full of inspirations.�
He pulled out a book on vintage autos. There were half a dozen bookmarks in it. He turned to a page with a photograph of the profile of an automobile and his finger traced the curve of a front fender. �Finding THAT curve lead to a necklace design that I�ve made ten grand from. In a catalogue of machine parts he pointed to a particular gear. This gave me an idea for a series of rings, with stones inlayed into the openings of the teeth of the gear. That lead to a series of my best selling rings.�
Over the next hour or so he took me on a trip down Memory Lane as he went through just a few of the books in his Inspirations Library, recalling designs he�d used in his jewelry line. His favorite books were about flowers � photographs of floweres, line drawings of flowers, technical illustrations � of leaves, thorns, seed pods, stamins, microscopic images of pollen grains and cells in a leaf.
�I buy two or three hundred dollars worth of books like these � a month. And I really LOOK at each image, in each one, in a lot of different orientations. I start with the book upside down, then go through it �from the side�, then from �the other side�.
He hesitated, probably wondering if he should reveal one of his design secrets to a potential future competitor � he was afterall, a businessman. But my enthusiastic interest in his work � along with my obvious lack of knowledge and skill in the jewelry making business � opened him up to �sharing�.
�If you look at anything familiar, in a familiar way � its normal orientation � you�re probably going to see what you expect to see. And this is true even when you look closely at a detail in the picture. But if you rotate the image, turn it sideways or upside down � THEN you start to see what�s ACTUALLY there, not what you EXPECT to see.�
Photo after photo he showed me what he was talking about. And with each photo he �re-oriented� he pointed out a line or a flowing surface and described how he�d taken that line or surface and designed a piece of jewelry from it. He even showed me sketches and drawings and a finished piece he�d developed from one of the photos.
My enthusiastic interest in what he was sharing with me prompted him to take me out behind his shop, to another of his Inspirations Libraries � of driftwood from the nearby beaches � stacks and piles and stands of driftwood � little pieces, big pieces � tons of driftwood. He rummaged through a cluster before finding the one piece he was looking for.
�See this area � right here? See how the grain swirls, how the softer wood was worn away by sand and surf. I used this texture and pattern in all sorts of ways � rings, buckles, earrings, necklaces. I got a dozen designs from just this little area of this piece of driftwood.�
Now, pushing forty years later, I find myself acquiring potential inspirations.
Rather than collecting 2D images, some of 3D objects, or actual 3D objects, I�m gathering things that can produce light or might be able to play with light, things that have the ability to generate sounds � a voice if you will � and things that can move � and make other things move, directly or indirectly � equivalents to muscles and tendons .
More interesting � I�m learning of, and acquiring, things that can sense things � or sense changes.
�Eyes� that can �see� � both visible as well as invisible to us light, and changes in light,.
�Ears� that can hear sounds and because audible sounds is merely vibrating air, sense other vibrations � which we can�t hear.
There are senses of touch capable of identifying not only contact � but pressure and directions as well, along with the amount of change and rate of change of pressure.
There�s even an equivalent to our inner ear�s head orientation mechanism � 3 axis accelerometers and even little gyros.
But the most fascinating of what�s available in the Dr. Frankenstien repetoire of potential inspirations is the available BRAINS � that can be taught � to do things � autonomously. Thankfully, these can be acquired without the need for picks and shovels, saws and scalpels, or late night trips to cemetaries If I happen to electrocute one � no deep hole to dig to bury it in.
So now to you. Do YOU collect things that may act as inspiration for, or become part of, some future piece you�ll do? (wood hoarding excepted of course)
Are some of those collected as possible inspirations for a future piece items� �unusual�?
Care to share how it/they kick off ideas � and where that�s led?
How long will you keep �unusual� possible inspirations � before you have to dispose of them � to make room for stuff you�ve just picked up � hoping they�ll be inspirational?
For those with a Better Half, how does he/she affect your �collecting� and the size of your Inspirational Library?
Has a friend or relative hinted that YOU may be the subject of an upcoming Intervention show?
Re: Hoarding or Potential Inspirations?
Steven Antonucci
Can I cop a plea?
steven antonucci
and get a reduced sentence for mini hoarding?
It all started simple enough. Growing up with my grandfather, he always had that coffee can full of rusty odds and ends, so of course, I had to follow tradition. I am a little more organized than he was, as I attempt to sort my odds and ends into size, and metal types.
Then there is the box of 'recycled' screws and bolts. If I have to throw something out, I strip it of all metal fasteners, just in case... and I might even save the wood if it's in good shape for a shop shelf, or something.
From there, it gets into tinkering. When you are a woodworker, you move wood from log to lumber to bits-too-pretty-to-burn-that-I-am-saving-for-someone-who-makes-small-things. It's not really hoarding if you are doing it for someone else...
Then someone shows you glass beadmaking, metal forming, blacksmithing, pysansky eggs, encaustic, block printing... and you are pretty much screwed.
Yeah, I started a shop clean out project about 2 years ago and I was doing great until I realized that I'd never get anything done in a 'clean shop'
Steve the mini-hoarder
Betty Scarpino
Re: Hoarding AND Inspiration
Betty Scarpino
For me, inspiration can come from the few items I collect (or hoard), either physically or in my mind. I tend, however, toward not keeping things or physically collecting objects -- being surrounded by things just doesn't interest me very much. But I do collect ideas and images in my mind and those ideas and images influence me greatly by combining in ways that don't necessarily directly connect with the original image or idea.
For objects themselves, looking at my turned objects upside down is sometimes helpful. Also, looking at something outside of its intended location can help me see things in new ways. I once placed a large egg next to a small vessel, just to keep both of them out of harms' way, and the result two days later was seeing them as a pair rather than individual objects -- why not have an egg that has outgrown the "nest"?
I have a friend who is probably a #9 hoarder. She is very creative, but all those "things" actually stifle her ability to make work. There's just too much to take care of in order to actually work. So, I think a balance needs to be achieved. Yes, hoarding can be helpful for inspirations, but having too many things around can be paralyzing.
Re: Can I cop a plea?
George Van Beynen
Thanks Steve, I too remember my grandfather, he always had that coffee can full of rusty odds and ends also...........In fact, I think I now have it out in the pole building. ;)
