All one piece but turned from both ends to hollow out and a plug placed in the bottom
The idea was to have a look like this had been found on a ship wreck diving excursion
I remember diving on a wreck 20 years ago and finding brass port holes and iron remnants That when cleaned up looked like this
The process I use is to apply 2 coats of rust then verdigris over the top 2 coats .By keeping the surface wet with the acid as long as you can (I use tissue paper and load with acid ) In some areas the acid eats through the verdigris and the rust shows through
The texturing was burnt in with a scaplel blade to form a basket weave pattern and the wings were by the old dod dot dot i am getting bored doing this pattern
The wall thickness of the vessel is the same as the wings and sanded smooth
Are you making your own rust and verdigris? Or can these be purchased?
I've made a number of my own "stains" and colorings such as ferrous nitrate (nitric acid and steel wool), black walnut stain, real milk paint (powdered minerals, milk, etc.). What vehicle are you using to carry the rust and verdigris?
