Carved vessel continued
steven antonucci
So the first photo showed the beginnings of the carving, with about 3/4 of the carving to still be done. A buddy of mine was over yesterday, and insisted that I had turned the form and then attached the other piece before patinating. I assure you that this is all one piece of wood.
Next to the piece is Frog Tape, which is supposed to create a sharp line and prevent bleed by turning the liquid into a gel. The adhesive has some kind of chemicals in it. Unfortunately, the wood sucked in some of the patina chemicals harder than the tape did, and I've been trying to bleach them out. I have to try lemon juice to see if it works better than Kleenstrip.
The rim was burned with my Priddle style pen, and took about 30 minutes and a million little dots. Final sanding (after the stains are out) is all that remains. Starting to like the idea of bleaching the bottom though...
Comments welcome.
Steve
