cupcake box
cupcake box
cupcake box
Here is the latest version. The icing started to cure and got too hot in the icing tube so I had to really rush the icing. I'll have to solve that problem. I could barely hold it so naturally it's pretty sloppy.
Re: cupcake box
Steven Antonucci
Carve the icing
steven antonucci
May take a lot longer, but it will definitely not get hot in your hands!
Looks good enough to eat, John.
S
Re: cupcake box
Re: cupcake box
Galen Vetterick
I'd take a white or yellow cupcake with that lemon icing.
What do you mean we can't eat it!
It looks that good!!
Re: cupcake box
Re: cupcake box *LINK*
Don Evans
John:
I think the answer to your continued quest is a Gel mixture.
Liquitex makes one that I used for texturing instead of epoxy which I would use in the past to mix dry powdered color material.
You can get it at Dick Blick in a 16 oz jar to try and cost is just under $10.00.
What I would do on the cupcakes is turn the wood on top of the cake and then cover that with this stuff instead of using this to create all the frosting. Putting it on with a cheap brush using dabbing action and swirling lifting the brush to make peaks etc. Maybe even experiement with a knife to spread it just like real frosting.
You can add acrylic paint before application, mix paint and gel then apply.
You can also get it in gloss but I think the matte would be better.
Here is part number to search to get started: 00618-3086
Go to Dick Blick and search, let us know what you think.
Don
Dick Blick Art Supply
