Re: Help, no quill lock/Safety note
Don Evans
There is a quill lock on this drill press. It just isn't as handy as some.
As Wolf suggested, look at figure 10 on page 10 of the manual and note how they locked the quill down with the two nuts on the depth stop.
By moving the top nut up as far as you want the quill to go down and while holding the quill down with handles you then run the bottom nut up as far as it will go.
At that point the quill will stay in that position.
From a safety standpoint, I hope you will not use your drill press for routing and planing.
Both of those operations are not condusive to a drill press. Both operations will cause lateral pressure and vibration. The MT2 that holds the chuck in will fall out with vibration and with one of those planing things I'd hate to be standing in front of it when it falls out.
You really need a drawbar holding at MT in the quill for those type operations. Thats why milling machines use drawbars and collets instead.
Don
