IndyFest - Tormek and Woodcraft
Ray - Middletown, IN
There will be a Tormek setup in such a manner that you can use your Wolverine jig equipment to sharpen gouges. You can define the shape of the gouge on a standard 8" grinder then move to the Tormek to sharpen using the same setup you used on the 8". The only difference is the size of the wheels. After IndyFest we will try to get an article written to share with everyone.
Also we will take one of the inexpensive Woodcraft grinders and set it up so it will grind properly.
Ray
