using permanent marker
lea lysett
hello,
does anyone have experience with finishing over colored permanent sharpie. maybe a poly gel? or wax stick on the lathe? friction polish does not work. ugh it smeared. or maybe some insight on an alternative. its just that i have the pens. so i used them on a maple turning and need to finish/seal the top. probably not the best choice of coloring inside burned images but its what i had.
thankyou
lea
Re: using permanent marker
Bernie Weishapl
I use colored sharpies on my ornaments and always have used rattle can spray lacquer. But the first couple of coats must be extremely light or they will run. I generally put on 4 to 5 light coats but again light coats. I have also a couple of years ago used spray poly. Again light coats or it will run but they come out really well. Lacquer just gives a clearer finish.
Woodmangler
I use CA over colored sharpies on some maple pens... Works fine.
Richard Allen
Richard Allen
I am not sure what the solvent in the Sharpie pen is. Whatever the solvent is you want to be sure you use a finish with a solvent that doesn't dissolve the sharpie pen "ink".
Generally speaking I find that solvent based color can be safely finished with water based finishes. I also find that water based color can be safely finished with solvent based finishes.
The other way you can go is to use thin coats for fast drying finishes like shellac or lacquer.
The problem with using water based color or water based finish is that the grain will be raised. So it is best to raise the grain and sand it down a few times before proceeding with the coloring and finishing.
Good luck with your efforts.
I agree on the spray finish with lite coats.
jake Niedling
Finishing With Color
A couple of light applications of spray "fixative" (art supply store - Krylon Fixatif is the best) will seal your ink prior to using a heavier film finish like lacquer or shellac. You can also try the Prisma-color pens rather than the Sharpie brand.
Re: Finishing With Color
jim miles - charlotte, N C|
agree- I use wqter bqse finish. won't desolve ink. can put other finish over
