cutting a gluing
I spent the day cutting and gluing and flattening all the parts for 4 bowl from board projects. I finally got everything glued together late tonight. I should be able to start turning them tomorrow.
I worked on the cupcake icing. It has a problem I didn't anticipate. The thickener speeds up the drying. It also gets so hot you can't hold onto the icing tube. Oh well back to the drawing table.
I worked on the button box also. I should be able to finish it tomorrow.
