A55 Smoothing Plane
anyone turn Mulberry?
D. Hansen
I just received some mulberry. It is beautiful wood with a white section just under brown bark and a golden center. Since it is green it does turn easily but it eats up my gouges like they were tin. I usually can get through shaping of a 10 inch bowl before I have to go to the sharpener. then it is another two trips for hollowing the center. With this stuff though I worked up a sweat running back and forth. It is almost as if the center is acid filled. What an experience. Nice looking wood but had to work on my sharpening skills just to get a blank round.
Re: anyone turn Mulberry?
arkie
It's a cousin to osage orange, has many similarities including the wear on the tool, a tendency to split or check, and becoming a bit brittle across tthe grain when turned tthin and dry. I think it's pretty enough to justify all the trouble.
Mike Brazeau
In time you will be rewarded with the most beautiful brown color. The change is very dramatic, but takes a couple of years. Am told it can be achieved faster with ammonia fuming, but have not tried.
Bernie Weishapl
Mulberry turns great green and is pretty cracky when drying. When dry it does eat tools pretty quickly. It turns everything in the shop yellow when turning and sanding if you don't have a DC. Turns a beautiful brown color as it ages.
Juergen
I really like this wood. Wonderful golden color which contrasts nicely with the white sapwood. This piece was turned from an off-cut it's less than 1/8" thick, turned wet and left to air dry. No problems with cracking.
Beautiful pieces, Juergen
I really like the way the sapwood wanders in and out of the form.
Nice.
I love Mulberry...
GaryG in MD
Mulberry got me into woodturning. I saw a demo at a craft fair of making a very thin NE mulberry bowl. Bought the bowl and joined the local woodturning club. The rest is history.
Beautiful color as it darkens from yellow to a rich brown.
Just turned a piece a couple days ago.
Mine wasn't that bad on tools -- depends on the mineral content of the soil in which it is grown. ...Gary
Here's an example...
GaryG in MD
of some mulberry I was working with a while back.
I was turning this on the bias (between end grain and side grain) to put sapwood down one side and open up the grain structure across the top.
Easy to turn (even dry) and great color. (This billet was dried before turning.) ...Gary
