Veritas - Innovation in Tools
Handle wood pros/cons
I have a variety of tools with a variety of handle woods.
I've only made handles out of maple with the two 1/4" tools that I've made.
Jorge kindly sent me a large skew (thanks Jorge) with a large beefy tang. What sort of wood would be preferable for a handle? I usually use hickory or pecan for hammers but this is not a hammer. I have the "usual" domestics (ash, birch, cherry, black walnut, hickory, maple (hard and soft) and oak. I have some tropical wood also (Brazilian cherry, mahogany, rosewood).
All of the wood is 8/4 or better.
TIA.
Re: Handle wood pros/cons
Jesper, Denmark
Jesper, Denmark
Any of those will do, so find a piece of scrap in the right dimensions and use that.
Mike Stafford
Mike Stafford
Hickory makes a good handle regardless because of its weight and strength.
I have started to use heavier/more dense woods for my handles and making the handles shorter for tools that I use in front of me such as spindle gouges, skews, etc. I still like long handles for tools that will be hanging over the tool rest an appreciable amount.
Some of my favorite handles are made from cocobolo and verawood which are heavy and dense.
Steven Antonucci
Any itchy issues from the rosewoods?
steven antonucci
I get itchy from using them, and havig my sweaty hands wrapped around it for hours at a shot sounds like a good way to get a breakout.
For me, I use maple, oak and cherry. I don't sand them, since I use them as hammers, busted project beaters, and so forth. I also like longer, harder, heavier...
s
Hickory is doable
I've got some nice pieces that gotten from John K Jordan.
GaryG in MD
I have made handles from oak, maple, cherry, dogwood, and mesquite, and all have been quite successful. I've always enjoyed looking at Bill Grumbine's curly maple handles. Use a variety -- that makes it easy to ID your tools when all you can see is the handle sticking up. ...Gary
Mike Stafford
Knock on wood, no!
Mike Stafford
I have not developed any wood allergies except a bit of an astringent reaction to padauk which I don't like to use anyway because of how fast it likes to turn brown.
I have been using the more dense woods to make 9" long handles for tools that I use in front of me rather than to the side. Almost all of my spindle and detail gouges, small scrapers, Hunter tools and parting tools are now in handles with adaptors so that I can vary the length the tool protrudes. I just don't need a 15" handle for those tools that are not going to extend over the toolrest more than an inch or so.
For those who are less gravitationally challenged a longer handle may be necessary for proper leverage....
Re: Fitting a handle to a tang chisel.
Jorge Casta�eda
You are very welcome, The original handle looked like apple to me, but was broken so I made it one from hickory, it was 14" and I thought it was too long.
I forgot to mention how to marry the new handle to the chisel, The original handle had about 1" of the tang not inside the handle, so I repeated that.
Once you have your handle shaped and fitted with a ferrule, with a drill press, a thinner bit goes in almost as deep as you what the tang to go in, then start increasing the diameter of the bits as to drill out a step hole, the very top you widen with a chisel, but stay below the final size.
Now mount the chisel in a vise firmly, the blade of the chisel totally covered by the jaws, with a torch, map gas works just fine heat the tang to a dull red, pound in the handle and wait for it to cool in the vise, there will be smoke and you may want to have door and windows open and maybe a fan to blow it away, when it cools down, you are done and the tool is ready to work.
I have an old "uni-bit".
I was going to use that. The taper is roughly similar - so I won't drill as deep.
Terry Scott
I like a bit of weight in the handle so Id use Jarrah or some other hardwood
John Veerkamp
Osage Orange makes wonderful , heavy , strong handles
Brad Vietje
Brad Vietje
I would use something hard, heavy, and preferably coarse in texture, like Ash or White Oak for roughing tools, and I recommend only the lightest sanding, and probably no finish at all. I'd use something finer grained like Sugar Maple or Osage Orange for tools used for precise finish work, and these would be sanded and polished.
My 3 cents,
Brad Vietje
Newbury, VT
FWIW, my drilling technique
Usually tangs are a uniform thickness, and they taper only in the width dimension, so I use a bit that corresponds to the tang thickness. I start by drilling a center hole to depth, then, with the drill still running, I rock the handle side-to-side, in-and-out, until the hole is tapered on both sides. It's not a super accurate technique but fast and good enough for me. I generally use the torch method for inserting the tang into the tapered hole, as Jorge described. This method leaves more wood around the tang for support.
