best way to mount this log?
ILYA Z
I found this log the other day:
I think it's white oak. The log is about 10" in diameter and 10" long. I want to turn something bowl/vase-shaped out of it using the good side of the log as the bottom and trying to avoid removing bark on the opposite side of the log or making any marks on the partially rotten inside.
What's the best way to initially mounting it on a lathe? The photo shows my first pathetic attempt at it. The top of the (future) bowl is at the headstock pressing against a piece of plywood. No glue, screws or anything. Right after I put it up like that I realized that turning the lathe on would probably be suicidal so I didn't do it.
Is there a better way? I guess one solution would be to use a faceplate. This would be OK except I would have to deal with screw holes later. Any other options?
Also, can you think of anything else I should keep in mind before or when turning it? E.g. should I be worried about the top curved "shoulders" of the log breaking off?
Thanks much!
