1642 spindle lock
1642 spindle lock
1642 spindle lock
Dennis
I have a Jet 1642 lathe, love it, but would like to be able to lock the spindle, there is only a button, that does not stay in place, any else come up with a means to lock the spindle in place?....sure would make some operations easier and free up some hands...thanks...Dennis
Re: 1642 spindle lock
When you got your Jet 1642, there should have been a small metal indexing "pin" with screw threads on the pin. This pin fits in one of the three holes at the front of the "collar" around the spindle shaft.
Your spindle shaft has several holes in the shaft. When you screw the pin in one of the holes, you "lock" the spindle in place. As you have three holes in the collar and four holes (or so) in the shaft, you can pretty much hit every "o'clock" (or 30 degrees).
If you have lost the pin (it is small, so many people have either misplaced it or thrown it away with the packing), replacement pins are available from Jet.
By the way - make sure you take the pin out after you are finished. The lathe doesn't run very well with the pin in position.
Russ Fairfield
Your lock-button has a metal guard that is held in by 2 screws, remove one of the screws and slightly loosen the other one. Push in the button and twist the guard enough to hold it in and lock the shaft. This a faster lock than looking for the pin to hold the spindle end.
Don Orr
Russ's solution is exactly what I use and it works very well. Remove the lower screw and loosen the upper one.
guybratt
I have seen on powermatics where the button guard is drilled through over the button and a pin is inserted to hold the button down. Also the pin is bent in a fashion to obstruct the stop/start from being pulled out. Attach a small light pull chain to the pin and lathe for loss prevention. Maybe check the mustard monster site for a pic????
Doc Green
Here's a photo of what Russ is suggesting. I had to add three washers and use a longer screw at the top so the guard would stand off enough to swing over the button when it is depressed.
Woodmangler
Here's what I did... spur of the moment kind of thing, but it has been there ever since... and since it works I never changed it :)
Bob Rogne
I agree with Russ. But put a leather or rubber washer under it for good friction fit.
Bob R
Mark
One of the guys in our club drilled two holes dead center on the locking pin. Then when he wants to lock the spindle, he pushes in the pin and inserts a cotter pin through the holes to keep it in place. Remove the pin or you fry a belt.
John Peck
Solutions with pictures at the Mustard Monster site, https://docs.google.com/View?docID=d4b7vjd_30dgfrd5&revision=_latest
