THE WOODRAT IS BACK!
Bowl steady question
I made a bowl steady out of Three layers of half inch plywood. The wheels come in from the corners on slides that are half inch by about two inches. Its more flexible than I thought. Is it really important for it to be very rigid or will have the desired effect if its flexible? I have not tried it yet, but it seems the dampening might help. Any thoughts?
Re: Bowl steady question
Barry I can only answer part of your question. I made a 3 wheel steady out of plywood. It is also flexible but seems to work on the time that I have used it. I don't know if a really solid one would work better or not. I keep thinking I'll build one out of steel but this one still works when I need it so I put the steel one off.
Bill Howatt
You just have to try it, Barry.
I think you will find it a big help. I have a Oneway Bowl Steady which is a substantial steel plate and vertical pipe with 1/4" thick wall the wheel mounts are fasted to. It visibly flexes to accommodate any uneveness in the workpiece.
I recall reading a post a long-time ago, perhaps by somebody on this forum that the steady should not be totally, rock-solid or something will break. I think there was a suggestion of using a spring on the nut and bolt that holds it to the bed if the steady is that rigid.
Bill
I was thinking...
That its being flexible might be a good think. If it is "just right" it should add a lot to the process without crushing the bowl.
I have been working on this thing a long time. Actually, I made it a year or more ago and went to put it on the lathe and realized the shelf above the lathe interfere. (Tiny violins playing the "small shop blues") So I set it aside. In cleaning up I decided to try again or trash it. I cut off the rear arms to clear things. Realized they did not have to close to zero. Hmmm, maybe I'll convert it to a three wheel steady and let the back one stick straight back.
Where is the best location for the wheels? Now that I think about it, it seems you would want on right in front of where you would be cutting.
Re: Bowl steady question *LINK*
Russ Fairfield
I made a tgemporary steady out of 2x4 lumber and skate wheels 10 years ago when I needed one of them in a hurry, and have been using it ever since. It took only 20 minutes to make and it was cheap.
Don't laugh. It is as rigid as the best of the commercial steadies, and it has 6 wheels so there is a lot more control and vibration damping with a lot less pressure than any of those I have used with 3 wheels.
My homemade steady rest
Dick Hines
Dick Hines
I made a steady rest for hollow forms but I guess it could be used for bowls.
Materials were 2- 3/4" all thread rods.
12- bolts and washers
2-oak boards
4- schooter wheels
4- bolts and nuts to fit wheel holes
1- 1 1/4" square tubing
I used it the big BLM hollow form I posted last week.
Russ' wheels
Jimmy Edwards
Russ I get a vision of a little grandson standing there with tears in his eyes as granpa rips away his skates out of his hands to get his wheels. Or are these available at HF, HD, Lowes etc.
Re: Russ' wheels
Russ Fairfield
WalMart has new wheels at a reasonable price. I bought some of the better wheels they had at the time for $15 for a dozen. That was 15 years ago, so they may be a bit higher now.
You can also buy almost new shoes at the nearest yard sale for about $2 a pair, or at the Salvation Army or similar store for about $5 a pair, but you will have to remove the wheels from the shoes.
Dick Hines
Re: Russ' wheels
Dick Hines
Russ, you are telling your age now. I bet you remember .20 gas too.
Re: Russ' wheels
bill crommett from Seneca
Doesn't everybody remember 20 cent gas ? The kind you had to pump the handle to fill the big glass cylinder ?
