More bowl from board tutorial
Finally had time to breath at work so I thought I would post a few more of the steps I followed when doing the Oak bowl from a board.
Here I'm cutting the rings off with a parting tool from the inside out. Wear a glove. I cut my finger and thumb as the ring comes free.
Then the rings are glued. You could just use a weight but I have a large clamp. At this stage you can align them any way you want.
One of the downsides of cutting the rings fairly narrow to get a taller bowl is that the bowl is already fairly thin and supported by very little wood. The bowl chatters quite a bit even if your pretty good at turning thin. To solve this I cut a large plywood ring and simply push it against the rim while turning the outside. It is amazing the difference it made. Not only in reducing the chatter but how clean the cut was as well.
Thanks to a photo of one of Terry Scott's pieces I thought I would try the hot glue stabilizer on the outside. Mad does that work well. However it does blow all the dust right back in your face so if you didn't have a face shield on before this you will now.
This bowl was already thin but due to some defects in the wood I had to turn it really thin. The Gauge-T really helps with this. The marks on the Gauge-T are 1/16" so as you can see it's pretty thin. It weights 5.5 oz.
It was so thin I didn't dare use the vacuum chuck so I pulled out the big jaws to turn the bottom.
Here is the finished piece. Well actually I plan to put a few more coats of finish on but it photographs well this way.
Re: More bowl from board tutorial
Galen Vetterick
John
Thanks for showing your turning methods.
Wonder if it would be any safer if you had some radial stiffeners hot glued to the back of the disc to start. When you cut through the larger rings they would stay in place. Might make for cleaner last cuts and save your hand?
Just thinking out loud.
Now if I only had a bigger lathe to make it worth a try. (Jet 1220)
Galen
Re: Contrasting rings - how?
Henry (Raleigh NC)
John - I've read your "bowl from a board" series of posts - but I can't recall if you have addressed the method of creating the contrasting (partial) rings. Do tell how you did this.
I really like this piece of all the pics you have posted in this series, and you may have inspired me to try some of this.
Henry
I'm ahead of you. I've thought about double stick taping a few strips to the back to support the ring. What I did on the last few was cut until you can hear it get thin and the slow the lathe down and make the final cuts. The ring still comes off at 100 or 200 rpm but it's not as scary.
Henry I couldn't remember if I did that or not. I have the images on my work computer so I'll try to post those tomorrow. I have 2 quick jobs to shoot in the morning but while I'm downloading those I can post the photos of how the contrasting rings evolve.
Lan Brady
John,
Thanks for this tutorial. It makes me want to try one.
I look forward to your update post on the contrasting woods.
Also, how do you unglue the supports when you are through?
Thanks, Lan
Your waste block is square but
Rich Pearson in Mill Creek, WA
you also have very thin rings to start with.
How do you get the waste block accurately centered? Any wobble at all takes away some badly needed thickness.
Do you have a magic method?
Re: Contrasting rings - how? *LINK*
HeatherAinAK
Here was some earlier progress shots. I really enjoy these.
Heather
earlier progress
Thanks, I got busy last night and didn't look
Thanks I Knew I forgot something.
Getting the glued on supports was touch at first. I tried a heated knife, almost broke the bowl. Thought of the heat gun but yellow glue will also break with heat.
I ended up using my G string. No not the one I wear, the one off my guitar. Actually it may have been the high E. I put handles on it so it looks like a weapon and then used it like one of the wire tree limb saws. I just sawed back and forth and it cut right through it.
I used a slightly heated putty knife to scrape off the larger residue and then used alcohol on a rag to get rid of the residue. It worked but left some stuff in the pores. Next time I'll finish the outside first so the glue is more easily removed.
Contrasting rings are sapwood.
Henry (Raleigh, NC)
Ahhh I saw those progress pics, but did not recognize that the contrasting rings were part of the sapwood of that board before it was sliced apart.
So I need just the right board to try to recreate the wonderful effect that John has there.
Thanks
Henry
Re: Your waste block is square but
Very magic. When I first draw the rings using the compass there is a center point. I use one of the square blocks that I use for my hand mirrors. (You could use anything) These have a 3/8" hole drilled in the center. I put a 3/8" brad point bit through the hole, put the point on the center left by the compass and just push the block down. I apply glue first of course. I use medium CA with Accelorator so I can easily pop the waste block off later.
That's only when I am working on the large flat pieces to get them ready to use the parting tool.
The the glued up bowl blank, which often gets off center, I put the face side over my chuck, or if it won't fit I stick it on larger wooden faceplate that has been trued up. I bring the tailstock up lightly and rotate the bowl and watch the top rim. I adjust the tailstock until the top rim doesn't wobble. Then I put more pressure on the tailstock and turn a very short tenon on the bottom. This is really just an alignment feature for the wasteblock that will be glued on for the actual turning.
Then I turn a rebate into the wasteblock that exactly matches the short tenon. I glue these together and your bowl will be running true. for many many years I didn't have a chuck and this is the way I started almost every project. It's more secure than a chuck and if you are careful with the hole for the tenon it will line up better than a chuck.
Mark Damron video on custom ring tool *LINK*
Dick Coers
John, I know you like to make tools, but have you seen Mark Damron's video? If you start making a lot of these bowls, it might be a real nice accessory!
Mark Damron's ring cutter
Re: Mark Damron video on custom ring tool
Ooooh that is cool. I already have the cross feed table so it's just a matter of buying the bearing assembly, some cutters and little aluminum
I just invented a new tool- will make one
I think I can make a special bar and front tool rest for my captured bar system to cut rings. If I have time I'll try to make one this weekend and see if it works. I may not have the right cutters that I would need but might be able to modify some HSS cutters if I have any left that I haven't cut down.
GaryG in MD
John, Thanks for the tutorial. Very helpful. That's another beauty, and I would love to pick it up and feel the lightness. ...Gary
