Thanks John Lucas
Thanks John Lucas
Thanks John Lucas
Terry Scott
Thanks go to John who kindly sent me his information sheet on hand mirrors
Unlike me but I thought I better read the instructions before starting
These are all made from New Zealand Rimu with 150mm mirrors
The picture came up lighter than the wood is (my box brownie skills are lacking )
I had trouble finding mirrors, as I couldn't wait due to the customer wanting a mirror for his wifes birthday I had to get them cut
The Glazer did a good job apart from the sizes of the 13 mirrors (I had to get this many minimum order)
I should have measured each mirror and marked the wood and the mirror as when I came to glue in the mirrors hello !!! they varied in size by 2mm . Luckily I made six on the trot and had 13 mirrors to juggle
The next fun I had was drilling the handle holes some ended up being mirrors for right handed people ,
I sent the Pictures to the customer tonight a bonus is he said he wants then all six as he cannot decide and has a family of girls
Still we shall see as they say the money isn't the bank
comments welcomed id apreciate your feedback before I use up the rest of the Mirrors
Re: Thanks John Lucas
Terry I've done all kinds of mirrors over the years but have yet to make one with a stone or medallion in the middle. I like that idea. When I first ordered cut mirrors I assumed they would be cut with some sort of circle cutter and be exact. Not, they not only were not the same size but were often out of round which looked terrible in a round piece of wood.
Nicholas Tuzzolino
John: Is this the same info on your Mirror Frame Drilling Jig Article?
If not, I would like to get an update if possible, especially the turning part.
Thanks, Nick
Joel
Looks pretty good. I made a few awhile back, two of them cracked the mirror glass after the wood moved, how do you account for wood movement in yours?
Joel I teach everyone to undercut the wood at the bottom of the opening for the mirror glass. I do this by taking a spindle gouge (I prefer the Thompson detail gouge) I put the bevel on the wood with the flute facing straight out. I push the tool into the side wall of the opening and then give it a clockwise twist so the flute moves up. This cuts with the bottom side of the cutting edge and gives you a tapered groove that the mirror can move into as the wood shrinks.
Nick I'm not sure which article you are refering to. What I sent Terry was a version of what was published in the AAW demonstrator handout book. If you send me an e-mail I can send the same thing.
Nicholas Tuzzolino
I would like that info. tuzz@dslextreme.com
Terry Scott
I may have made a boo boo as John said use silicone I used max bound which is what Glazers use to stick glass and mirrors on They all have a mm clearance so hopefully !!!!
Terry I switched from the professional mirror glue simply because the Silicone is 1/3 the price. The other glue works well. In fact they look and smell the same so my thought was that I was paying $8 for a small tube of the mirror glue when I could buy Clear silicone caulk (which I still think is the same thing) for $5 for a large tube.
Joel
Thanks guys, I had used double sided carpet tape, it held even after the glass fractured.
