Hat #6 notes
Hat #6 notes
Steven Antonucci
Hat #6 notes
steven antonucci
With each hat I make, I am trying to learn something and optimize the process. Today, after dropping a white oak board on my shin and having it mash my leg down to the ankle, I decided to pause on making my shave horse and turn another hat.
I marked out the hat on the bottom and trimmed a 6"x15" mostly rounded hat blank. I had an idea to speed up the making of the hat that I wanted to try, so I marked close to center on the top side of the blank, and I drew a circle about 8-9" in diameter. Next, I took my chainsaw and cut down from the top face of the blank until the bar was level with the top surface. About 8 quick cuts later, I had an octagon cut into the top part of the hat.
I flipped the blank up on it's side, and then using the face cuts as a guide, I cut into the side to connect all of the top cuts. Each cut removed the little wedge from the outer surface until I was completely around the diameter of the blank. In the end, I probably spent 5 minutes doing this, but removed 10# of wood from the blank. the scraps get burned, so the firewood pile is getting bigger. Shavings get mulched, so the shaving pile was about half what it was from the #5 hat.
In the end, more firewood, less clean-up. I like it.
I also have tried to see if I can bend them a little bit more along the grain to get a better fit. I tried hand scraping the inside end grain to thin in a little bit more than the sides of the hat to hopefully get a little bit more give out of the wood. Time will tell if it worked or not.
No pics yet... just the tips!
Steve
Re: Hat #6 notes
Steven Antonucci
Finding a good hat model...
steven antonucci
Is hard to do around here!
This is my yougest son, Luca. He's 4 and a half, and not really thrilled about wearing a wooden cowboy hat. #6 is OK, and by far my best technically, but I think that some of the others have had better shapes in the crown. I have a little bit of sanding to do, and probably another day of drying. So far, it started the day at 5.95 ozs, an is down to 5.75 oz. After I finish touching up some of the hat with some paper and a card scraper, I think it will get down to 5.5ozs.
I really need to make a jig so I can make myself a hat. Also think I'm going to need a bigger lathe :-)
S
Re: Hat #6 notes
Re: Finding a good hat model...
Randy Gleckler
They are looking good and I've really enjoyed watching your progression. Mistakes, Successes and all.
Re: Hat #6 notes
Great Pic Steve !
Don Orr
The hat's not bad either ;) .
