BLAST IT - with what?
charlie belden
As if I need ANOTHER area to explore - I picked up this small sandblasting "cabinet" - with a roll around cart base - for $25. The gun is a bit large for the inside space and with two hoses - one for medium and one for air - it's awkward as hell to use in the tight available working space.
Came with some of what was probably beach sand - of a range of grits. - and a ceramic nozzle with a 3/16" hole. Picked up a 100 lb. bad of "fine" sifted Montery Beach Sand to play with. Works, but cuts REALLY slowly - even on doug fir.
So now I'm looking for a smaller "gun", more aggressive medium, a source or two for guns and mediums and some info on using a sandblaster on wood - preferably turned wood. Any help would be greatly appreciated.
Lots of possibilities with this "surface enhancement" tool - buyt probably also another Learning Curve to climb.
